Cylindrical Patch for interFoam
Old   December 11, 2006, 15:10
Default I am trying to simulate water
vatant is on a distinguished road
I am trying to simulate water drop (of diameter D) in moving air. For this purpose, I would like to solve a flow field and introduce a liquid drop into the system.
I see that boxtoCell would create a box type patch..how can I create a spherical fluid patch. If my case is axisymmetric what should I use?
I also did see the rotatedboxtoCell but not sure if its the right thing to use.
vatant is offline   Reply With Quote
Old   December 12, 2006, 01:23
Default HI: i am also interested in
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
HI:
i am also interested in the question.there are lots of branches in TopoSetValue.could anyone explain how to use these utilities
waynezw0618 is offline   Reply With Quote
Old   December 12, 2006, 03:13
Default You'll have to create your own
Mattijs Janssens
mattijs is on a distinguished road
You'll have to create your own code to generate and write out a faceSet (which can then be used to make a patch). (the faceSet application with the boxToFace, rotatedBoxToFace etc. sources just handles the most general cases)
faceSets are very easy to code, e.g.
// Generate faceSet called f0 with size 100
faceSet f0(mesh, "f0", 100);
// Add faces based on face centre
forAll(mesh.faceCentres(), faceI)
if (mesh.faceCentres()[faceI].x() < 0)
f0.insert(faceI);
// Write to file
f0.write();
mattijs is offline   Reply With Quote
Old   December 12, 2006, 04:08
Default hi Mattijs:thanks but i jus
wayne.zhang
hi Mattijs:thanks
but i just want to set a circul cylinder inside the hydrocylone which i want to patch a air-core,is there any basic sources ?how can i use them? thankS!
Transient interFoam with MRF jaswi OpenFOAM Running, Solving & CFD 18 October 20, 2011 23:29
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH mkraposhin OpenFOAM Running, Solving & CFD 3 September 4, 2011 09:42
Runing InterFoam for 3 D damBreak case Patch issue nishant_hull OpenFOAM Running, Solving & CFD 5 February 18, 2009 00:32
InterFoam floooo OpenFOAM Running, Solving & CFD 0 November 3, 2008 11:00
Ask for a Phd thesis about interFoam zjucfd OpenFOAM Running, Solving & CFD 1 July 3, 2007 11:10
