Hi all,
I need to change so
Hi all,
I need to change some of the parameters to the ODE solvers (specifically SIBS & KRR4) to try to get a big (stiff) kinetic scheme to work in dieselFoam. The KRR4 gives me an 'exceeded maxtry' error, SIBS gives me a 'step size underflow'. I found that maxtry is set to 40 in the ODE code -- I'd like to set it to a bigger number. I can't figure out how to overwrite the defaults from my chemistryProperties file. Any suggestions? Thanks! Mike |
so why dont you create
so why dont you create a new ODe-solver with a different entry for the size? (or change the (original) sources and recompile?) stephan |
| All times are GMT -4. The time now is 10:27. |
