Material interfaces and the laplacian operator |
November 7, 2006, 08:35 |
Hi to all
I am fairly new to
Ivor Clifford
Rep Power: 17 |
Hi to all
I am fairly new to OpenFoam so if anyone could help me, I'd appreciate it. I am solving a simple diffusion equation of the form fvm::laplacian(gamma,phi) == Src How does one implement an effective gamma at a face separating two cells with different gamma values (i.e. different materials). This would be done for any solid heat conduction problem (where an interface between solid materials of different conductivities exists). As I understand it, it is necessary to define an interpolation scheme and add a weighting parameter to the laplacian operator. Could somebody please clarify how this is done practically in OpenFOAM, or at least point me to an example where this is done. Thankyou in advance |
November 7, 2006, 09:03 |
I think the answer is in the s
Dragos
Rep Power: 20 |
November 7, 2006, 09:30 |
When you specify the Laplaciam
Hrvoje Jasak
Rep Power: 33 |
When you specify the Laplaciam scheme in a dictionary, you will have something like this:
laplacian(nu,U) Gauss linear corrected; The word "linear" here tells you how to interpolate nu between the cell centres. The final word,"corrected", tells you how to calculate the surface-normal gradient needed by the operator - this one is corrected for mesh non-orthogonality. Other choices for the interpolation scheme can be made here, for example "harmonic" or any other scheme. Keep in mind that more complex schemes may requre more than one word, i.e. you may have additional parameters before the snGradScheme. Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
November 7, 2006, 10:06 |
Thankyou for your respons
Ivor Clifford
Rep Power: 17 |
Thankyou for your response. The method proposed there would work but it seems to me to be unnecessary to define a new mesh for each new material. I was thinking more along the lines of updating the face conductivities, so that when openFOAM calculates k*grad(T) at the face, the k value used is not a linearly interpolated value but rather a custom calculated value. This value would depend on the P and E cell conductivity values and the distance of each cell centre to the face. k=(dx_E+dx_P)*k_P*k_E / (dx_P*k_E + dx_E*k_P) |
November 7, 2006, 10:15 |
Thanks Hrv
Seeing the equatio
Ivor Clifford
Rep Power: 17 |
Thanks Hrv
Seeing the equation a gave in my last post, do you know if FOAM has a suitable scheme built in. Where will I find a list of the available schemes? Regards Ivor |
November 7, 2006, 10:31 |
Looking at your scheme, it loo
Hrvoje Jasak
Rep Power: 33 |
Looking at your scheme, it looks to me like harmonic interpolation. If you wish to implement your own interpolation, I've got a Laplace operator for you that will take the diffusivity as a surfaceScalarField, i.e. you can do the face interpolation beforehand in the code and present the face values directly.
Hrv
November 8, 2006, 02:17 |
Thanks Hrv
The laplace operat
Ivor Clifford
Rep Power: 17 |
Thanks Hrv
The laplace operator that will take the diffusivity as a surfaceScalarField sounds ideal. could I get that from you? Regards Ivor |
November 8, 2006, 06:36 |
You mis-understood me: the ope
Hrvoje Jasak
Rep Power: 33 |
You mis-understood me: the operator is already in the library so you don't need any code from me.
Hrv
November 8, 2006, 08:57 |
Right you are Hrv: I had anoth
#9 |
Ivor Clifford
Rep Power: 17 |
Right you are Hrv: I had another look at the doxygen documents and I see the operator you're talking about. Will give it a try... thanks
Ivor |
Question about the fvmatrix and Laplacian operator | liuhuafei | OpenFOAM Running, Solving & CFD | 6 | October 3, 2009 06:58 |
mixture type material as a phase material | Pablo | FLUENT | 1 | January 25, 2007 10:54 |
laplacian of temperature | seyed Farid hosseinizadeh | FLUENT | 0 | December 17, 2006 21:56 |
Material interfaces using the laplacian operator | cliffoi | OpenFOAM | 0 | November 6, 2006 10:42 |
Laplacian of a scalar value | J. Park | FLUENT | 0 | September 17, 2003 12:39 |
