I can finally release the modi
I can finally release the modified version of twoPhaseEulerFoam.
It includes: - Two additional drag models for gas-particle flows (Gidaspow, Syamlal-O'Brian). - Additional radial distribution functions for the kinetic theory and their derivative. - Additional granular pressure models and derivatives of the granular pressure coefficient. - Additional frictional stress models. - Variable averaging. - Implementation of a "packing limiter" algorithm to try to stabilize the solution when the kinetic theory is used. The implemented algorithm is just a trick to avoid numerical instabilities due to the discontinuity in the radial distribution function at the packing limit. However it requires quite a small time step. I think a more refined, less intrusive and robust method is needed such as some sort of relaxation of the granular pressure coupled to an implicit limitation on the particle-phase volume fraction similar to what done when the normal stress modulus is used in the same solver. Ideas and volunteers are welcome ;-) - Correction of the zeroGradient BC proposed by Henry Weller and sent to me by Rasmus (thanks!). I attach the code, an example and a detailed list of changes. |
Sorry for the multiple post. I
Sorry for the multiple post. I has some problem due to the size of the attachments.
The code and the changelog are here: http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif twoPhaseEulerFoam.tar.gz http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif Changes The example case is too big to be uploaded. It can be downloaded here: http://www.albertopassalacqua.com/in...id=9&Itemid=27 Best regards, Alberto |
