-   -   Velocity boundary condition problem related (http://www.cfd-online.com/Forums/openfoam-solving/59967-velocity-boundary-condition-problem-related.html)
dmoroian October 13, 2006 09:23
Hello again, I have a case th
Hello again,
I have a case that runs well using the conjugateFoam solver. Though, if I try to set an inflow velocity boundary condition of type pressureVelocity, I get the following error:
Starting time loop
Max Courant Number = 0.004
Time = 0.002
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
--> FOAM FATAL ERROR : gradientInternalCoeffs cannot be called for a defaultFvPatchField.
(Actual type pressureVelocity)
You are probably trying to solve for a field with a default boundary conditions.
From function defaultFvPatchField<type>::gradientInternalCoeffs( ) const
in file fields/fvPatchFields/basicFvPatchFields/default/defaultFvPatchField.C at line 421.
FOAM exiting
It works very well with type fixedValue. Anyone can tell me what is wrong?
Dragos
panara October 13, 2006 09:35
Can you explain more in detail
Can you explain more in detail your case?
geometry, BC, etc..
Daniele
dmoroian October 13, 2006 10:03
I have an anular cylidrical do
I have an anular cylidrical domain (grey) closed at one side and opened at the other. It should resemble with a mug, a cup or a bottle. This is the solid region.
The fluid region is represented by another inner cylinder. Both the inlet (green surface) and the outlet (blue surface) are located at the opening.
http://www.cfd-online.com/OpenFOAM_D...ges/1/3215.png
Though I don't think the geometry influences the error, since I have tried the same solver on other cases and behaves similarly.
Dragos
dmoroian October 16, 2006 08:46
I found the problem: the type
I found the problem: the type is pressureInletVelocity not pressureVelocity. It was in front of my eyes all the time.
I found this by searching all the libraries in OpenFOAM http://www.cfd-online.com/OpenFOAM_D...part/happy.gif
Dragos
