Gcc compiler
Old   October 6, 2006, 22:08
Default After I installed OpenFOAM on
shuo
After I installed OpenFOAM on Ubuntu I tried to compile some C++ codes(not a part of OpenFOAM) but the computer keeps referring it to OpenFOAM for some strange reason.
ie.
/home/shuo/OpenFOAM/linux/gcc-4.1.0/bin/../lib/gcc/i686-pc-linux-gnu/4.1.0/../.. /../../include/c++/4.1.0/istream:762: error: no type named 'off_type' in 'struct std::char_traits<wchar_t>'
Shuo
Old   October 7, 2006, 04:15
Default That's not referring to OpenFO
brooksmoses
That's not referring to OpenFOAM; that's referring to the GCC installation that you installed with OpenFOAM.
Remember, when you put the OpenFOAM bashrc (or cshrc) stuff in your .bashrc (or .cshrc) file? That also tells it to add things to your path, so that the copy of GCC that you installed with OpenFOAM comes earlier in your path than the system GCC. Thus, whenever you call GCC, regardless of whether or not you're doing OpenFOAM stuff, it runs that one.
In any case, it should work perfectly fine, except for any minor bugs that have been fixed between version 4.1.0 and the current version.
Gcc compiler shuo OpenFOAM Running, Solving & CFD 5 October 15, 2006 05:43
set compiler f77 andromeda Main CFD Forum 0 July 9, 2006 08:35
Compiler for UDF Alamgir FLUENT 5 July 31, 2002 20:44
compiler stephanie FLUENT 2 June 19, 2002 07:49
C++ Compiler for UDF Dmitriy Makarov FLUENT 1 December 12, 2000 02:41
