-   -   Customized solver to run in parallel (http://www.cfd-online.com/Forums/openfoam-solving/60004-customized-solver-run-parallel.html)
hsieh September 9, 2006 08:26
Hi, I have a customized sol
I have a customized solver (not a standard OpenFOAM solver). It ran fine in serial. When I ran it in parallel, AMG failed. Changed to ICCG/BICCG, ran with only a warning at each time step. I have not checked whether the results are correct.
When looking at the code, is there a way to tell whether it is "parallel-ready"?
Pei
jojo September 20, 2006 12:57
I have a customized solver as well. However, I do not manage to run it in parallel while it runs fine in serial.
I get the following message:
It seems that [at least] one of the processes that was started with
mpirun did not invoke MPI_INIT before quitting (it is possible that
more than one process did not invoke MPI_INIT -- mpirun was only
notified of the first one, which was on node n0).
mpirun can *only* be used with MPI programs (i.e., programs that
invoke MPI_INIT and MPI_FINALIZE). You can use the "lamexec" program
to run non-MPI programs over the lambooted nodes.
It seems that wmake compilation of custom solvers has an issue with parallelization (I have seen another post with the same problem).
hartinger September 20, 2006 14:46
Hey, I think first you woul
Hey,
I think first you would need to understand the existing solvers like GaussSeidel. Set up a very simple test case like 10x1x1 cells and a very simple equation and check whether each processor receives what you would expect.
markus
mattijs September 21, 2006 04:59
- make sure your solver uses a
- make sure your solver uses argList to extract the command line options
- make sure your solver gets called with a -parallel option
