Questions from a beginner
Old   September 10, 2006, 22:50
Default Hi guys I can't find the sour
shuo
Hi guys
I can't find the source codes for the fvschemes and fv solution dictionaries. Also when the codes has something like:
solve
( fvm::ddt(rho)
+ fvm::div(phiv, rho)
Is this a class, function declaration or an object? Can I access the codes for them?
Cheers
SHuo
Old   September 11, 2006, 07:58
Default Hi Shuo, first you can have
Markus Hartinger
hartinger is on a distinguished road
Hi Shuo,
first you can have a look at the programmers doxygen, which is automatically generated code documentation:
http://foam.sourceforge.net/doc/Doxygen/html/
You can access all code, everything is open-source.
You find the code of the 'fvm::' in $FOAM_SRC/finiteVolume/finiteVolume/fvm/
and the 'fvc::' in $FOAM_SRC/finiteVolume/finiteVolume/fvc/
'fmv::ddt' and 'fvm::div' are templated functions belonging to the namespace 'fvm' (finite volume matrix). Each function returns a matrix which can be solved for.
'solve' is a templated functions defined in $FOAM_SRC/finiteVolume/fvMatrices/fvMatrix
regards
Markus
hartinger is offline   Reply With Quote
CFD beginner:- Help needed, general questions on Free jets? (Fluent 5.2.3) Wong, R.Y.T. Main CFD Forum 5 October 22, 2010 00:51
Couple of Beginner Questions hydromodeler OpenFOAM Installation 5 February 27, 2008 04:34
i am beginner for cfd robbin CFX 1 December 31, 2005 11:54
CFD beginner saravanan Main CFD Forum 3 August 16, 2003 07:38
i am a beginner!!!! BINAYA KUMAR DHAR Main CFD Forum 3 January 18, 2001 00:33
