I want to distretize im
I want to distretize implicitly the terms: div((C*C) & V) and div(V*C) where C is a vector. This is only possible explicitly using the fvc function. I want to solve for the vector V and for stability reason implicitly. Anybody know if this is possible and how? Petr |
Petr,
I don't think you can
Petr,
I don't think you can make the terms fully implicit until a coupled equation capability is introduced into the library. In the interim, you can modify the method used for the velocity equations in Reynolds Stress Transport Models, in which the stress divergence is aranged as an implicit diagonal and an explicit correction. For the first term: volScalarField traceCC = (1.0/3.0)*tr(C*C) or volScalarField traceCC = C & C; fvm::grad( traceC, V) - fvc::grad( traceC, V) fvc::div( (C*C) & V) For the second term (one possiblility might be) gradC = fvc::div(C) diagGradC = diag(gradC) fvm::Su( diagGradC, V ) - diagGradC * V + fvc::div(V*C) hope this helps Dave |
Dave, thank you for the kind r
Dave, thank you for the kind reply. I understand what you mean, but have some problems implementing. grad does not exist in the fvm scope, do you mean div:
fvm::div( traceCC, V) - fvc::div( traceCC, V) + fvc::div( (C*C) & V) then traceCC must somehow be interpolated to surfaceScalarField, I think. for the second term I think you mean gradC = fvc::grad(C)? For some reason diag() is not recognized, but according the programmers guide it should work. The compiler says: error: 'diag' was not declared in this scope Might the name have changed? Petr |
Petr,
You are correct abou
Petr,
You are correct about my div/grad substitutions (In the first expression I misread your post) To get traceCC as a surfaceScalarField, you could use fvc::interpolate(traceCC), The diag() function does not appear to have been implemented for volTensorFields. Further, since fvm::Su and fmv:SuSp only take a volScalarField as a first argument, you wouldn't be able to use a tensor anyway. You could try using: traceGradC = tr(gradC)/3.0; fvm::Su( traceGradC, V ) - traceGradC * V + fvc::div(V*C); Also, div( (C*C) & V) would seem be a scalar, i.e., d_i(C_i C_j V_j) Dave |
