-   -   Lagrangian Derivative (http://www.cfd-online.com/Forums/openfoam-solving/60066-lagrangian-derivative.html)
coops August 20, 2006 18:08
Is it possible to take the Lag
Is it possible to take the Lagrangian derivative of a volVectorField (U) and (in a seperate equation) also a volScalar Field (T)? At the moment when I try to use these I get the following errors:
fvc::DDt(U) + ....
error: no matching function for call to 'DDt(Foam::volVectorField&)'
and for T:
fvc::DDt(T)+....
error: no matching function for call to 'DDt(Foam::volScalarField&)'
If it is not possible can anyone suggest a solution?
Thanks in advance,
Shaun
hjasak August 21, 2006 01:43
Sorry for stating the obvious,
Sorry for stating the obvious, but the substantial derivative requires a velocity field, right? Therefore in order to evaluate it, fvc:: (or fvm:: for that matter), needs access to the fluxes - that's why you need to arguments. Have a look at fvcDDt.H for the list of available function signatures.
Hrv
