Higher order downwind scheme
Like Tree1Likes
  • 1 Post By jelmer
Old   August 4, 2006, 09:09
Default Does anyone happen to know if
jelmer
Does anyone happen to know if there is second order version available of the downwind scheme? I would like to apply a second order scheme for the convection in the adjoint Euler equations. So far I could only find (and use succesfully) the first order downwind scheme, other schemes seem useless. There is nothing on downwind schemes in the manual either.
I tried to use schemes for vector fields in order to upwind according to the adjoint characteristic direction which is opposite to the physical characteristic direction, but this wasn't a cure either.
regards, jlmr
Old   August 4, 2006, 11:03
Default I think you mean upwind. Downw
Eugene de Villiers
eugene is on a distinguished road
I think you mean upwind. Downwind is unconditionally unstable.
eugene is offline   Reply With Quote
Old   August 4, 2006, 12:50
Default Be careful Eugene: he is solvi
Hrvoje Jasak
Be careful Eugene: he is solving the adjoint equation.
Hrv
Hrvoje Jasak
Old   August 7, 2006, 08:26
Default Thank you Hrv for explaining..
jelmer
Thank you Hrv for explaining...
So, nobody knows either who has implemented the downwind scheme so I can contact him or her?
Then my other question is: would copying and modifying (for instance) the MUSCL scheme from upwind to downwind be a smart and easy way to write a higher order downwind scheme myself...?
jlmr
Old   August 9, 2006, 06:43
Default found it! simply add '2': G
jelmer
Gauss downwind 2;
does the trick. Nice second order accurate solution!
jlmr
mm.abdollahzadeh likes this.
Higher order polynomial problem... Markas FLUENT 0 February 20, 2008 16:44
Higher order elements Renato Pacheco FLUENT 0 September 24, 2007 07:33
FVM-higher order scheme K S Chang Main CFD Forum 6 December 9, 2003 10:26
MI & Higher-Order Convective Scheme. Ana Main CFD Forum 0 September 22, 2003 05:01
Higher order FVM Sergey Smirnov Main CFD Forum 10 April 15, 2000 01:49
