-   -   Higher order downwind scheme (http://www.cfd-online.com/Forums/openfoam-solving/60077-higher-order-downwind-scheme.html)
jelmer August 4, 2006 09:09
Does anyone happen to know if
Does anyone happen to know if there is second order version available of the downwind scheme? I would like to apply a second order scheme for the convection in the adjoint Euler equations. So far I could only find (and use succesfully) the first order downwind scheme, other schemes seem useless. There is nothing on downwind schemes in the manual either.
I tried to use schemes for vector fields in order to upwind according to the adjoint characteristic direction which is opposite to the physical characteristic direction, but this wasn't a cure either.
regards, jlmr
eugene August 4, 2006 11:03
I think you mean upwind. Downw
I think you mean upwind. Downwind is unconditionally unstable.
hjasak August 4, 2006 12:50
Be careful Eugene: he is solvi
Be careful Eugene: he is solving the adjoint equation.
Hrv
jelmer August 7, 2006 08:26
Thank you Hrv for explaining..
Thank you Hrv for explaining...
So, nobody knows either who has implemented the downwind scheme so I can contact him or her?
Then my other question is: would copying and modifying (for instance) the MUSCL scheme from upwind to downwind be a smart and easy way to write a higher order downwind scheme myself...?
jlmr
jelmer August 9, 2006 06:43
found it! simply add '2': G
Gauss downwind 2;
does the trick. Nice second order accurate solution!
jlmr
