July 21, 2006, 11:28 |
I have never used openf
Bryan Godbolt
Rep Power: 17 |
I have never used openfoam before. I want to simulate a deformable body on a microscopic scale. This means I need to solve incompressible viscous flow at low reynolds number in an infinite space. Can someone point me in the right direction as to what solver I should be looking at or any other tips ? I'm also fairly new to fluid dynamics so if something i've said doesn't make sense I am happy to clarify. Thanks, Bryan |
July 21, 2006, 13:32 |
Perhaps icoFoam or simpleFoam.
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Perhaps icoFoam or simpleFoam. But if you want to study deformations, I think you might need to look into DynFoam or some such. Have you searched the forum for similar cases?
July 21, 2006, 13:36 |
Thank you for your reply.
I
Bryan Godbolt
Rep Power: 17 |
I have searched the forum and the internet for information on low reynolds number simulation in openFoam and I haven't been able to find anything saying whether current solvers in openFoam are capable of this. How can I find out whether icoFoam or simpleFoam will work? |
July 21, 2006, 13:39 |
If the flow is laminar, icoFoa
Rep Power: 21 |
If the flow is laminar, icoFoam or one its moving mesh capable variants (search the forum, there are a good number of folks working on moving mesh) will do just fine. If you're referring to low-Re turbulence models, there is info out here[1].
[1] http://www.opencfd.co.uk/openfoam/tu...tml#turbulence |
July 23, 2006, 22:08 |
Just to clarify with laminar f
Bryan Godbolt
Rep Power: 17 |
Just to clarify with laminar flow icoFoam will work even at very low reynolds number?
July 24, 2006, 11:34 |
Totally. It should in principl
Rep Power: 21 |
Totally. It should in principle at least. Or maybe is there a stokes solver around in OpenFOAM?
July 24, 2006, 12:25 |
If the Re number is really rea
Eugene de Villiers
Rep Power: 21 |
If the Re number is really really low, just remove the convection term, + fvm::div(phi, U), from icoFoam's Ueqn and recompile. Instant Stokes flow.
August 2, 2006, 11:32 |
The re number that i want to s
Bryan Godbolt
Rep Power: 17 |
The re number that i want to simulate is very low. I tried the idea of removing fvm::div(phi, U) from icoFoam and recompiling but I now get this error when I run icoFoam:
--> FOAM FATAL IO ERROR : Unknown symmetric matrix solver BICCG Valid symmetric matrix solvers are : 4 ( ICCG GaussSeidel DCG AMG ) file: /home/bryan/OpenFOAM/bryan-1.2/run/tutorials/potentialFoam/lowrecylinder/system/ fvSolution::U at line 28. From function lduMatrix::solver::New(const fvMesh&, Istream&) in file matrices/lduMatrix/lduMatrixSolver.C at line 100. FOAM exiting I have not changed the fvSolution file and if I put the line back in and recompile if works fine once again. Does anyone have any ideas as to what may be wrong? I am not very familiar with c++ so I may be missing something obvious that is done by this line. Are there any other ways of acheiving creeping flow in openFoam? |
August 2, 2006, 11:37 |
Yes. OpenFOAM knows whether th
#9 |
Hrvoje Jasak
Rep Power: 33 |
Yes. OpenFOAM knows whether the matrix you have assembled is symmetric or assymetric. For symmetric matrices it will use symmetric matrix solvers, which are prettier, faster etc. than assymetric solvers.
When your equation contains the convection term, you will have an assymetric matrix, which requires an assymetric solver, e.g. BiCCG. When you remove it, the matrix will be symmetric and you need to use a symmetric solver, for example ICCG - this is exactly what the error message says. Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
Display Modes | |
Reynolds number | Fede | CFX | 4 | November 6, 2006 12:51 |
Reynolds number | Joseph | FLUENT | 0 | January 30, 2006 16:40 |
Reynolds number??? | Joseph | FLUENT | 0 | January 30, 2006 16:33 |
Help with Reynolds number: Re | Isa | Main CFD Forum | 2 | December 4, 2003 10:47 |
Reynolds number | Mult | Main CFD Forum | 1 | April 12, 2002 12:02 |
