DdtPhiCorr
Like Tree48Likes
  • 19 Post By hjasak
  • 6 Post By ville
  • 2 Post By malaboss
  • 2 Post By ville
  • 10 Post By eugene
  • 8 Post By ville
  • 1 Post By Tushar@cfd
Old   January 17, 2006, 05:52
Default Hi all, I'd like to know mo
Luca M.
luca is on a distinguished road
I'd like to know more about DdtPhicorr term. I have not clear in mind the theoretical derivation of this operator. It's similar to Rhie-Chow interpolation for Co-located variable arrangement?!
Moreover, it's possible to use it in steady simulations?!
Thanks in advance
Luca
luca is offline   Reply With Quote
Old   January 17, 2006, 18:10
Default This term accounts for the div
Hrvoje Jasak
hjasak will become famous soon enough
This term accounts for the divergence of the face velocity field by taking out the difference between the interpolated velocity and the flux. Have a look at:
finiteVolume/ddtSchemes/EulerDdtScheme/EulerDdtScheme.C
in the main library:
rDeltaT*fvcDdtPhiCoeff(U.oldTime(), phi.oldTime())*
fvc::interpolate(rA)*phi.oldTime()
- (fvc::interpolate(rA*U.oldTime()) & mesh().Sf())
Unfortunately, I don't think there's anything written about it.
Enjoy,
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   February 13, 2006, 14:03
Default Does this add more numeric dis
diablo80@web.de
sampaio is on a distinguished road
Does this add more numeric dissipation to the scheme?
What should I expect if I remove this from the oodles main code? Can I live without it? Or what were you guys trying to achieve when you come up with this?
(I m running incompr LES)
Thanks a lot!
luiz
sampaio is offline   Reply With Quote
Old   July 27, 2006, 11:12
Default Hello everyone, I detected so
Rolando Maier
rolando is on a distinguished road
Hello everyone,
I detected some inconsistency, while experimenting with the term "fvcDdtPhiCoeff" in "ddtPhiCorr".
Probing the pressure signal of a LES yielded different results depending on using the present calculation of "fvcDdtPhiCoeff" or using a constant value, as was done in FOAM version 1.1.
If I use the present version the signal looks a bit wavy (f~1/deltaT) with small amplitude.
If I use a constant value then the signal looks smoother.
I´m not sure, if it is numerical noise in the one case or a wrongly smoothed signal in the other case.
Can anyone give me a hint?
Thanks in advance
Rolando
rolando is offline   Reply With Quote
Old   October 18, 2010, 02:52
Default ddtPhiCorr meaning
Aldo Iannetti
aldo.iannetti is on a distinguished road
Could you explane me why in turbDyMFoam (OF 1.5-dev) I have:
phi = (fvc::interpolate(U) & mesh.Sf());
//+ fvc::ddtPhiCorr(rUA, U, phi);
Can you explane me better the meaning of ddtPhiCorr term? why in some solvers is commented and in other (es. pisoFoam) is not?
thanks
Aldo
aldo.iannetti is offline   Reply With Quote
Old   December 13, 2012, 14:52
ville vuorinen
ville is on a distinguished road
Thanks a lot!
luiz
I have quite interesting experiences regarding the flux interpolation in PISO:
+ fvc::ddtPhiCorr(rAU, U, phi);
In lid driven cavity and turbulent channel flow (DNS) this calculation of phi
works very well. However, for a laminar, inviscid Taylor-Green vortex the term
+ fvc::ddtPhiCorr(rAU, U, phi); turned out to dissipate kinetic energy very strongly.
On fine grids about 10% of the initial energy within a few eddy turnaround times.
When I removed the + fvc::ddtPhiCorr(rAU, U, phi) term things seemed to work
much better.
My solution: Runge-Kutta 4 and the projection method - I implemented the solver. I would very much appreciate comments regarding the necessity of
+ fvc::ddtPhiCorr(rAU, U, phi) in PISO!
Best, Ville
ville is offline   Reply With Quote
Old   October 28, 2013, 16:22
Malik
malaboss is on a distinguished road
I have been investigating this issue too.
I think ddtPhiCorr is approximately equal to : UfaceOld*Area - phiOld, (if we assume that this difference is close to zero, for the simplest case).
You can look at this link which sums it up :
http://www.scribd.com/doc/48195039/ddtPhiCorr
So why would we need to carry this difference in the computation of phi ?
My guess is that in the piso algortihm you correct for the non orthogonalities and do not have phi = Uface*Surface anymore after the correction.
Forcing phi to be equal to this on the next iteration would be a bit silly so you want to keep that correction. This is the ddtPhiCorr.
Thus it should not appear where no correction that we want to keep is done.
However this doesn't explain why Ville found an excessive dissipation of kinetic energy when ddtPhiCorr is there. Could you give more details about how you figure this out ? During your simulation did you correct non orthogonalities ? Was your grid non orthogonal ?
Regards,
minh khang and Brandon233 like this.
malaboss is offline   Reply With Quote
Old   April 20, 2014, 22:52
Zhipeng Zhou
zhouzhipeng77 is on a distinguished road
Hello everyone ,
I am new to OpenFOAM , and I am working on a melting problem , but I can understand the following code
volScalarField rAU("rAU", 1.0/UEqn.A());
surfaceScalarField rAUf("(1|A(U))", fvc::interpolate(rAU));
U = rAU*UEqn.H();
surfaceScalarField buoyancyPhi(rAUf*ghf*fvc::snGrad(rhok)*mesh.magSf( ));
phi -= buoyancyPhi;
while (pimple.correctNonOrthogonal())
fvScalarMatrix p_rghEqn
fvm::laplacian(rAUf, p_rgh) == fvc::div(phi)
p_rghEqn.setReference(pRefCell, getRefCellValue(p_rgh, pRefCell));
p_rghEqn.solve(mesh.solver(p_rgh.select(pimple.fin alInnerIter())));
if (pimple.finalNonOrthogonalIter())
// Calculate the conservative fluxes
phi -= p_rghEqn.flux();
// Explicitly relax pressure for momentum corrector
p_rgh.relax();
// Correct the momentum source with the pressure gradient flux
// calculated from the relaxed pressure
U -= rAU*fvc::reconstruct((buoyancyPhi + p_rghEqn.flux())/rAUf);
U.correctBoundaryConditions();
Can anybody help me to explain this , or introduce me some papers I should read ?
Thanks
Zhipeng
zhouzhipeng77 is offline   Reply With Quote
Old   July 24, 2014, 11:02
yijin Mao
alundilong is on a distinguished road
Originally Posted by zhouzhipeng77 View Post
Hello everyone ,
Thanks
Zhipeng
Hi Zhipeng:
I think you may read through this to have some basic idea. http://openfoamwiki.net/index.php/Op...hm_in_OpenFOAM
and also go through how governing equations(especially pressure equation, in OF, we solve "real pressure equation" instead of "pressure correction equation") discretization is realized in jasak's PhD theis. http://www.h.jasak.dial.pipex.com/
for the buoyancy approximation, you may read through any material found online.
Best.,
alundilong is offline   Reply With Quote
Old   July 28, 2014, 03:59
ville vuorinen
in this paper some OpenFOAM related matters are discussed including syntax. Also
the adhoc ddtPhiCorr term is discussed from effect point of view although its origin remains unclear. I noted that the extra term has actually been removed in some newer solvers.
On the implementation of low-dissipative Runge–Kutta projection methods for time dependent flows using OpenFOAM®, Computers & Fluids, Volume 93, 10 April 2014, Pages 153-163, V. Vuorinen, J.-P. Keskinen, C. Duwig, B.J. Boersma
fumiya and godfatherBond like this.
Old   October 29, 2014, 11:48
Eugene de Villiers
eugene is on a distinguished road
ddtPhiCorr is a form of Choi correction and was originally intended to remove time step size dependency from Rhie-Chow interpolation.
http://nht.xjtu.edu.cn/paper/en/2002206.pdf
In FOAM there is however an additional ad-hoc component fvcDdtPhiCoeff that appears to be purely empirical in nature.
The Choi correction is dissipative in nature, but it is consistent. There appears to be an issue with the FOAM implementation in that setting fvcDdtPhiCoeff to 1 (full Choi correction) results in instabilities. So it might very well be the case that the implementation is flawed in some way. Investigations are ongoing.
eugene is offline   Reply With Quote
Old   October 30, 2014, 06:01
anonymous
ssss is on a distinguished road
Does this mean that ddtCorr is influenced by this supposed bug? Will results differ much because of this possible flaw?
Thank you very much for answer.
ssss is offline   Reply With Quote
Old   November 2, 2014, 04:19
Johan Lorentzon
pi06jl6 will become famous soon enough
Since this thread dates back to previous version of OF, which one do we talk about, since in the bugreport someone has pointed out the Uf to be an issue and DPhiDtCorr involves this variable? I am not an expert on this subject so I am looking forward the outcome of this "investigation".
pi06jl6 is offline   Reply With Quote
Old   December 10, 2014, 23:08
T. Chourushi
Tushar@cfd is on a distinguished road
Dear All,
I am also confused with the additional term "fvc::ddtPhiCorr(rUA, U, phi)" for the phi formulation. Did anyone dig into it? What is the actual significance of it?
Best Regards!
Tushar@cfd is offline   Reply With Quote
Old   December 11, 2014, 07:06
ville vuorinen
It is an ad hoc term which is probably added to stabilize some certain flow situations.
Sometimes it does not matter, sometimes it has a strong effect. There are more
questions than answers but please see
where we demonstrated what happens if it is there and what if it is not.
Best,Ville
Tushar@cfd, Tobi, D.R. and 5 others like this.
Old   December 11, 2014, 07:12
T. Chourushi
Best,Ville
Thank you very much, this information is really helpful.
Best Regards!
minh khang likes this.
Old   October 8, 2018, 17:01
gu1
Guilherme
gu1 is on a distinguished road
Hi
Based on the topics written by each one of you, I would like to ask two questions...
1) If I want to remove the extra term of phi (related below) from my pisoFoam (OF 5.0) should I remove the highlighted term? I would like to do tests with the original PISO algorithm...
"phiHbyA",
fvc::flux(HbyA)
+ fvc::interpolate(rAU)*fvc::ddtCorr(U, phi)
2) The increase in the number of correctors on the PISO algorithm (nCorrectors) will influence the accuracy (and perhaps dissipation) of my study?
Best.
gu1 is offline   Reply With Quote
