-   -   Debug switchSet cannot find DimensionedConstants (http://www.cfd-online.com/Forums/openfoam-solving/60117-debug-switchset-cannot-find-dimensionedconstants.html)
guido_adriaensen May 12, 2006 05:43
Hi, I recently made the swi
I recently made the switch to OF 1.3. After adjusting my solvers, I tried to run a testcase to see if it was working, but I get the following error instantly when I launch my app.
debug::switchSet(const char*, dictionary*):
Cannot find DimensionedConstants in dictionary /home/guido/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/controlDict
I have taken a look at the controlDict file, and it indeed does not contain a debug switch for DimensionedConstants. Should I add this myself? Or is there something else wrong?
kind regards
Guido
gzink July 5, 2006 09:33
I have the same problem when I
I have the same problem when I start to try running rhoSimpleFoam in OF 1.3. I've tried to add a line for DimensionedConstants in the controlDict, but it doesn't seem to fix the problem. Anyone know what to do?
Thanks
Greg Z.
gzink July 10, 2006 10:12
I added a line for Dimensioned
I added a line for DimensionedConstants and it shows up in both the controlDict file in the terminal, and when I edit the controlDict in FoamX. However, when I try to run rhoSimpleFoam from the command line, I still get this error:
Cannot find DimensionedConstants in dictionary /root/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/controlDict
as mentioned by Guido previously. Has anyone had any experience with this issue? Any help would be greatly appreciated.
Greg Z.
gzink July 11, 2006 07:39
Thanks Guido! That worked gre
Thanks Guido! That worked great!
Greg Z.
mattijs July 11, 2006 12:40
Hi Guido, could you file a
Hi Guido,
could you file a bug report for this (FoamX not being able to edit controlDict)?
