Twophase channel flow
Old   July 10, 2006, 07:20
Default I have to implement a two-phas
Alberto Passalacqua
I have to implement a two-phase channel flow solver, starting from twoPhaseEulerFoam.
I'd like to add the same procedure of channelOodles, which adapts the pressure gradient in order to keep the mass flow rate constant.
The problem is that the velocity equation for both phases doesn't contain the pressure gradient, so I'm not sure on how I can extend the procedure to this solver. Where should I add the pressure gradient?
Thanks in advance,
Alberto
Alberto Passalacqua
Modelling Supersonic TwoPhase Flow with Phase Change wes OpenFOAM Running, Solving & CFD 9 July 27, 2021 11:05
maintain a constant flow rate in channel flow ? Lewis Main CFD Forum 2 September 28, 2010 11:35
parasitic flow in twophase flow simulation dusky.He Main CFD Forum 3 April 9, 2007 13:09
one-fliud formulation twophase flow with phase cha Dusky.He Main CFD Forum 0 December 30, 2005 10:27
EulerLagrange approach for twophase flows gellert OpenFOAM Running, Solving & CFD 5 June 29, 2005 08:23
