July 5, 2006, 03:20 |
I've got a channel with
I've got a channel with a fixed velocity inlet and fixed pressure at outlet. What BC is correct to choose for pressure at the inlet if I dont know the actual pressure value? It is set to zeroGradient by default but it doesnt seem physicaly correct. While runing my case I get "time step continuity errors" which i guess is caused by this. Thanks /Erik |
July 5, 2006, 05:21 |
okay for so far. The ne
Anja Stretz
Rep Power: 17 |
okay for so far. The next error message after starting the time loop is: --> FOAM FATAL IO ERROR : file "inlet.dat" does not exist Where does the inlet.dat have to be? I've tried it in "case/0/", in "/derivedFvPatchFields/timeVaryingUniformFixedValue" and in "/solvers/icoFoam". Can someone please help me? Thanks Anja |
TKE & TDR in pressure inlet BC | Sisir | FLUENT | 2 | October 24, 2018 11:03 |
velocity inlet vs pressure inlet | cheong | FLUENT | 6 | April 9, 2011 03:07 |
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet | gabriel | OpenFOAM Running, Solving & CFD | 16 | September 30, 2009 18:20 |
Pressure Inlet BC | Prasad | FLUENT | 3 | January 4, 2009 22:55 |
How can I set the inlet pressure? | moon | FLUENT | 7 | August 19, 2003 14:17 |
