July 1, 2006, 21:47 |
Hello Friends
1.
In the pr
kumar
Rep Power: 17 |
Hello Friends
1. In the present PISO loop in say interFoam we have laplacian(rUAf,pd)=div(phi) say , eqn A both rUAf , phi are evaluated at the cell face. dimension of rUAf = (m^3 . S)/kg dimension of phi = m^3/S dimension of pd = kg/(m.S^2) since pd is at the cell centre . i found the laplacian of (rUAf,pd) as div( rUAf*|S|*grad(p)_face ) which equals div( [m^3 .S /kg] * [m^2] * [kg/(m.S^2)]*[1/m]) and this works out to be div ( m^3 / S ) . which equals the RHS eqn A. first question is IS THIS CORRECT ?? 2. when i multiply both sides with density as shown in eqn B below why is it dimensionally incompatible ? phi=phi*rhof rhof is the density at the face of cell with dimensions [kg/m^3 ] rUAf_rhof = rUAf*rhof laplacian( rUAf_rhof , pd)=div(phi) equation (B) . But now OpenFOAM gives the following error --> FOAM FATAL ERROR : Different dimensions for = dimensions : [0 3 -1 0 0 0 0] = [1 0 -1 0 0 0 0] From function dimensionSet::operator=(const dimensionSet& ds) const in file dimensionSet/dimensionSet.C at line 158. FOAM aborting This is really strange. phi has changed its dimensions on expected lines , BUT NOT the LHS of eqn B . thanks in advance. Kumar |
July 3, 2006, 06:08 |
Dear Friends
Any comments o
kumar
Rep Power: 17 |
Dear Friends
Any comments on the above. I am really stuck with my work thanks in advance kumar |
July 3, 2006, 14:34 |
Dear Friends
Any comments o
kumar
Rep Power: 17 |
Dear Friends
Any comments on the above would be most welcome thanks kumar |
PEqnflux in compressible and incompressible PISO loop | dbxmcf | OpenFOAM Running, Solving & CFD | 3 | September 27, 2019 06:13 |
PISO loop | 21kalee | OpenFOAM Running, Solving & CFD | 2 | January 15, 2008 05:31 |
laplacian of temperature | seyed Farid hosseinizadeh | FLUENT | 0 | December 17, 2006 21:56 |
Mistake in PISO loop for interFoam solver | kumar2 | OpenFOAM Running, Solving & CFD | 3 | June 30, 2006 18:26 |
loop(p,I->p) how this loop works? | Sinan | FLUENT | 0 | January 18, 2005 18:04 |
