For Fidap, we set boundary con
For Fidap, we set boundary condition for outlets as:
BCFLUX( ADD, N3, ENTITY="outlet", CONSTANT=0.0 ) According to the Fidap manual: BCFLUX: "normal component of total normal stress", and "N3" is the outlet patches' normal direction. and we did not set pressure conditions. |
Does Fidap make an assumption
Does Fidap make an assumption about the outlet pressure or does it assume zero-gradient or some other kind of extrapolation?
I can not find it from the man
I can not find it from the manual. Probally they do it secretly;)
Thanks again for all your help! |
I've got an idea for you: try
I've got an idea for you: try solving potential flow (using potentialFoam) and then start the Navier-Stokes solution from that - it may give you what you expect.
Hrv |
Hi Hrvoje Jasak,
I am a n
Hi Hrvoje Jasak,
I am a new OpenFOAM user and I want to solve the continuity and 2 D navier stokes equations at steady state for incompressible flows. Where should I start? Can you give me some tips please. Regards adil |
Use simpleFoam. Start
Use simpleFoam. Start by reading the manuals and do the tutorial; if you want to know the algorithm, have a look at my Thesis (available on-line) or any standard CFD book like Ferziger and Peric for example. Good luck, Hrv |
Hi Jasak,
Thanks for your
Hi Jasak,
Thanks for your advice but many thanks for your Phd Thesis. Regards adil |
I use interFoam to simula
I use interFoam to simulate rising bubbles I am interested in the detachment of the bubble from the inlet (where air is injected), and its shape after detachment. But the calculation are stopped because of the outlet conditions. I just want the bubble to disappear from the domain so I set Neumann boundary condition for U, pd and gamma. If the mesh is small enought, the first bubble disappear from the outlet. but from the next one, there is 4 small amount of air that stay on the boundary and keep growing and slow the computation My colleague use a free surface with their own code, so I tried to set air in the last cells, but the results are very strange and it still slows too much the computation Does anyone has experienced this problem before? or could guess some better outlet conditions? Thank you Aurelia |
