-   -   DNS Foam tutorial problem (http://www.cfd-online.com/Forums/openfoam-solving/60146-dns-foam-tutorial-problem.html)
msekandi1 June 21, 2006 07:05
Hi, I'm new to foam and I h
I'm new to foam and I have a problem running the dnsFoam tutorial and the ChannelOodles tutorial. I can construct the mesh and the tutorial will run. However, when I try to load up paraview to look at the results I get the following error message:
--> FOAM FATAL ERROR : Not implemented
From function void CyclicPointPatchField<patchfield,>::evaluate ()
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/CyclicPointPatchFie ld.C at line 187.
FOAM aborting
/home/msekandi/OpenFOAM/linux/paraview-2.4.2/lib/paraview-2.4/paraview-real: symbol lookup error: /hom e/msekandi/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libOpenFOAM.so: undefined symbol: cplus_demangle
Any assistance would be much appreciated.
Regards,
Michael Sekandi
luca June 21, 2006 07:50
Hi Michael, Simply commen
Hi Michael,
Simply comments from line 183-187 in the file $FOAM_SRC/OpenFOAM/lnInclude/CyclicPointPatchFie ld.C
and recompile
Luca
msekandi1 June 21, 2006 09:31
Hi Luca, I tried this solut
Hi Luca,
I tried this solution but it failed and I got the same error message again.
I'm not sure what's wrong with the code.
Michael
luca June 21, 2006 09:51
Hi Michael, this is the rig
Hi Michael,
this is the right way. I have encountered the same problem.
See also http://www.cfd-online.com/cgi-bin/Op...=7286#POST7286
Luca
msekandi1 June 23, 2006 08:39
Hi, I have tried and tried
I have tried and tried again, and still am encountering the same fatal error with ParaView for the dns and stressedfem tutorials. I think it's a path problem but I don't know what to do if it is.
Michael
hjasak June 23, 2006 13:27
Nope: you need to rebuild the
Nope: you need to rebuild the OpenFOAM library after you have done the stuff described above:
foamsrc
wmake libso
Enjoy,
Hrv
