November 8, 2011, 03:38 |
Convergence Problems using Spalart Allmaras
Denis
Rep Power: 14 |
i'm trying to investigate an airfoil under different angles of attack. I'm using the SimpleFoam solver with the Spalart Allmaras turbulence modell. I have a Re-Number = 2e06. For angels of 0 and 5 degrees, there is a good convergence, but for higher angles of attacks, like 10 and 15 degrees, there is no steady-state convergence. I don't understand the problem? Is there something wrong with my case (b.c., solver ??) I hope someone can help! Denis Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-06; relTol 1e-8; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 1e-12; } nuTilda { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p 1e-5; U 1e-5; nuTilda 1e-5; } } relaxationFactors { default 0; p 0.3; U 0.7; nuTilda 0.7; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 800; deltaT 1; writeControl timeStep; writeInterval 200; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(p) Gauss linear; grad(U) Gauss linear; } divSchemes { default none; div(phi,U) Gauss linearUpwind grad(U); div(phi,nuTilda) Gauss linearUpwind grad(nuTilda); div((nuEff*dev(T(grad(U))))) Gauss linear; } laplacianSchemes { default none; laplacian(nuEff,U) Gauss linear corrected; laplacian((1|A(U)),p) Gauss linear corrected; laplacian(DnuTildaEff,nuTilda) Gauss linear corrected; laplacian(1,p) Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { Outflow { type freestreamPressure; } Inflow { type freestreamPressure; } Finne-Wall { type zeroGradient; } frontAndBack { type empty; } } // ************************************************************************* // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (21.465 5.7515 0); boundaryField { Inflow { type freestream; freestreamValue uniform (21.465 5.7515 0); } Outflow { type freestream; freestreamValue uniform (21.465 5.7515 0); } Finne-Wall { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } } // ************************************************************************* // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0.14; boundaryField { Inflow { type freestream; freestreamValue uniform 0.14; } Outflow { type freestream; freestreamValue uniform 0.14; } Finne-Wall { type nutUSpaldingWallFunction; value uniform 0; } frontAndBack { type empty; } } // ************************************************************************* // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nuTilda; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0.14; boundaryField { Inflow { type freestream; freestreamValue uniform 0.14; } Outflow { type freestream; freestreamValue uniform 0.14; } Finne-Wall { type fixedValue; value uniform 0; } frontAndBack { type empty; } } // ************************************************************************* // |
November 8, 2011, 17:34 |
Vesselin Krastev
Rep Power: 20 |
I think that your main problem is that you are not limiting the gradient scheme for the linearUpwind convective interpolation. Try to apply the following gradSchemes:
grad(U) cellLimited leastSquares 1; grad(nuTilda) cellLimited leastSquares 1; In addition (but this will probably affect the computation speed rather than the accuracy), there is no need to have so severe relative tolerances compared to the absolute ones: put all the tolerances values to 1E-12 and the relative tolerances values to 0.05 for U and nuTilda and to 0.01 for p. Regards V. |
August 24, 2012, 17:57 |
Rafael Valenzuela Musura
Rep Power: 14 |
Denis, how did you solve the problem?, the same happens to me.
greetings. |
October 9, 2013, 13:19 |
Ali Baratian
Rep Power: 12 |
maybe the phenomenon is transient actually !!???
Display Modes | |
Gas-liquid vertical separator, problems with convergence | juliom | Main CFD Forum | 0 | October 5, 2011 21:20 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
NACA0012 Convergence Problems | StudentAndrew | CFX | 6 | November 21, 2005 07:49 |
Convergence problems | Simone | Siemens | 5 | June 29, 2005 11:48 |
Convergence problems | Chetan | FLUENT | 3 | April 15, 2004 20:13 |
