June 19, 2006, 01:59 |
I am solving for a turb
Ankur Gupta
Rep Power: 17 |
I am solving for a turbulent mixing (using LES model) of a passive scalar in a turbulent flow. The scalar has lower and upper bounds of 0 and 1 (as contrained by the boundary conditions). However, when solved, I get values in the computational domain which are like -0.001 and 1.001. What steps need to be taken in terms of solver settings (or anything else that would help) so as to aviod getting the scalar values out of the bounds ?? Thanks in advance. Regards, Ankur |
June 19, 2006, 05:03 |
You need to use a bounded diff
Eugene de Villiers
Rep Power: 21 |
You need to use a bounded differencing scheme for the scalar. E.g.
div(phi,gamma) Gauss limitedLinear01 1; |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
Bounded scheme gives unbounded solution | su_junwei | OpenFOAM Running, Solving & CFD | 3 | November 18, 2011 02:35 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
Bounded slice in Tecplot possible? | Sam | Tecplot | 1 | August 20, 2008 12:18 |
if two scalars calculation in scalfn.f | mspark | Siemens | 2 | April 5, 2004 02:49 |
