Running twoPhaseEulerFoam reco
Running twoPhaseEulerFoam recompiled with OpenFOAM 1.3 on a case which worked with 1.2, I get this error during the first time-step:
time step continuity errors : sum local = 2.39746e-15, global = 1.06432e-19, cumulative = 9.80563e-18 word::stripInvalid() called for string div(phi,Theta) Abortito What does it mean? Thanks, Alberto |
Sorry, I solved.
There is a s
Sorry, I solved.
There is a space in kineticTheory.C, between phi and Theta: word scheme("div(phi, Theta)"); I replaced with: word scheme("div(phi, Theta)"); and it works. A.P. |
stripInvalid is where it detec
stripInvalid is where it detects an invalid character in a word/string. It was switched off since it was found to take up non-insignificant amounts of time in OF 1.2. In 1.3 it prints an error message instead so one can fix the problem.
Please report any occurrences&fixes. If you're desperate to run with your incorrect code there is a debug switch for string in the OpenFOAM-1.3/controlDict you can set to 0 to switch the checking off (but please report any occurrences otherwise they'll never get fixed) |
Hi Mattijs,
I have a proble
Hi Mattijs,
I have a problem that seems to bee simular to the one obove. I have modified simple foam to do heat flux calculations with an application that works in v1.2 but gives the following error message in v1.3: erik@compadre:~/OpenFOAM/erik-1.3/run/tutorials/fluxFoam$ paraFoam . PD112 /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ fileName::stripInvalid() called for string T(kopia)~ /home/erik/OpenFOAM/OpenFOAM-1.3/bin/paraFoam: line 57: 8579 Aborted paraview paraFoam.pvs I see in buoyantFoam that there is a T.org file (in 0 dictionary) needed but I have done my code without. I wonder if my problem could be related to what is mentioned above or with the excluded T.org file. Many thanks /Erik |
Another fileName::stripInvalid() error
sorry to kick this old post, but since you asked to post these errors this seems like the most relevant location.
I'm trying to get FOAM to run some simple testcases by scripting them in bash. I'm using the $FOAM_RUN directory environment variable and I think that plays a role in why it fails. The output I get is: Code:
Exec : blockMesh -case /usr/scratch/cwit/OpenFOAM/cwit-1.5-dev/run/091026Try2/Cyl100Lo Code:
Exec : blockMesh -case /usr/scratch/cwit/OpenFOAM/cwit-1.5-dev/run/091026Try2/Cyl100Lo |
stripInvalid( ) error to solve Lid-driven cavity flow
hi, I try to do the first tutorial named lid-driven cavity flow, but when I try to run blockmesh a error message appears. I'm new user of openFOAM and I don't know what to do, please somebody know what happen?? :confused::confused::confused::confused:
the error is: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.0-113391ee57bd Exec : blockMesh Date : Aug 10 2010 Time : 12:35:12 Host : carlos-laptop PID : 3220 Case : /home/carlos nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time fileName::stripInvalid() called for invalid fileName UbuntuOne For debug level (= 2) > 1 this is considered fatal Cancelado please help me!!:(:(:( Carlos |
Hi, did you solve the problem? i met the same one just now, and looking forward to an answer...
Thank you so much! Quote:
