Two mesh solver in parallel
Old   June 11, 2006, 00:34
Default Hi, I am working on two mes
Ankur Gupta
ankgupta8um is on a distinguished road
I am working on two mesh solver (SimpleFoam-twoMeshes) that Mattijs wrote about a year ago. It is working fine in parallel only when I include transportProperties and turbulenceProperties dictionary in processor?/constant/ directory. I was also required to include fvSchemes and fvSolutions in processor?/system/ directory.
For a parallel run with just one mesh, it is not required to place the above mentioned dictionaries in processor?/constant/ and processor?/system/ directories. Then why is it required for two-mesh domains??
When I didn't include the dictionaries, I came across errors like this:
--> FOAM FATAL IO ERROR : cannot open file
file: /home6/axg330/OpenFOAM/axg330-1.2/run/tutorials/simpleFoam/pitzDaily_test/proces sor0/constant/region1/transportProperties at line 0.
So, what I inferred from the above error is that I need to place transportProperties in processor?/constant/region?/ directory, where region1 and region2 are my two meshes. When I placed 'transportProperties' in processor?/constant/region?/ directory, it worked fine. Later I tested a case where instead of placing it in processor?/constant/region?/ directory, I just placed it in processor?/constant/ directory and it worked fine in this case too.
So, how does OpenFoam work while looking for dictionaries ?? Does it first check constant/ directory and then /constant/region?/ directory??
Waiting eagerly for your valuable response(s).
Thanks!
Regards,
Ankur
ankgupta8um is offline   Reply With Quote
AMG Solver in parallel fra76 OpenFOAM Running, Solving & CFD 13 February 22, 2007 02:38
Solver error in Parallel run 255 M CFX 0 February 28, 2006 03:38
Parallel solver with 3.2 robbie Siemens 1 August 10, 2004 07:29
PHOE 3.5 parallel solver Phonics User Phoenics 1 December 19, 2003 02:58
3D PARALLEL SOLVER (MPI Lib) Saud Khashan Main CFD Forum 8 July 14, 1999 08:52
