Rookiequestions error solution singularity etc |
May 31, 2006, 10:28 |
Hey.
I have a few simple(?)
Marcus Hammar
Rep Power: 17 |
Hey.
I have a few simple(?) questions. First let me describe my situation: I have a (2m*2m) domain with a 0.2mØ circle in the middle. I am using simpleFoam. (is that ok?) Left boundary = inlet. Right boundary = outlet. bottom boundar = upper boundary = wall (moving with same speed as inlet value) circle = wall Questions: 1. What should i do with the "interior" regarding U,p,k,epsilon? 2. How do I know the smallest cellsize dx if i have converted my case from fluent? (i dont have any BlockmeshDict) 3. After having guessed arbitrary answers to the above questions I get "BICCG: Solving for Ux: solution singularity" etc for Uy,p,epsilon,k "time step continuity errors: sum local = nan, global = nan, cumulative = nan" Hope you dont mind my rookie-questions. Thanx!! /ham |
May 31, 2006, 13:05 |
You can look in the tutorial f
Pierre Le Fur
Rep Power: 17 |
You can look in the tutorial for simpleFoam. typical conditions/values for walls, inlet and outlet are in there. If you're using simpleFoam, I assume you're doing a steady-state calculation. So initial internal values can be set to any guessed values, it is not really important (I think), again look at the tutorial. For bottom and upper boundary, are they really walls or you just want to set it far free stream conditions?
try running CheckMesh Hope that helps Pierre |
June 1, 2006, 03:11 |
Thank you very much.
I will
Marcus Hammar
Rep Power: 17 |
I will look into this now. Hope Ill get it to work... Have a nice day. /Marcus |
June 1, 2006, 03:47 |
Okey, now it works better. htt
Marcus Hammar
Rep Power: 17 |
I compared all my files against the files in the tutorials until I found the error. I have to say its a bit embarrasing, but the kinematic viscosity was set to 0. For my defence I thought the default value of this property was set to something more logical... Now i just have to make sure that the freestream keep on running and does not end after the first iteration Thanx again Marcus |
Display Modes | |
error during solution initialization | Muhammad Usman Qureshi | FLUENT | 7 | March 31, 2008 08:26 |
Error modelling for a nonconverged solution | martapajon | OpenFOAM Running, Solving & CFD | 2 | August 16, 2007 14:13 |
solution singularity | litonx | OpenFOAM Running, Solving & CFD | 1 | February 21, 2007 02:32 |
Size of neighbour cells cause to solution error. | Stanislav Kraev | FLUENT | 2 | March 27, 2006 01:38 |
Urgent : Error in the Solution | Prasad Laxman Kane | FLUENT | 1 | August 19, 2002 08:06 |
