Using meshV and meshSf
Old   May 27, 2006, 08:46
Default Hello! I want to implement the
newbee
Hello! I want to implement the following code to a application I have created. But Im not quite sure how to use the mesh.V() and mesh.Sf() functions.
label holePatchi = mesh.boundaryMesh().findPatchID("hole");
if (holePatchi != -1)
solve
fvm::div(phi, T)
- fvm::laplacian(alphaEff, T)
+mesh.V()*q/(rho*Cp*mesh.Sf())
else
solve
fvm::div(phi, T)
In the if operation im interested in doing a calculation which involves multiplication with the surface area that is in contact with the patch called "hole" and im also intrested in dividing with the volume of this cell. When compiling this I get the following error message:
Making dependency list for source file fluxSimpleFoam.C
SOURCE_DIR=.
SOURCE=fluxSimpleFoam.C ; g++ -m32 -Dlinux -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -ffast-math -DNoRepository -ftemplate-depth-30 -I/home/erik/OpenFOAM/OpenFOAM-1.2/src/cfdTools/incompressible -I/home/erik/OpenFOAM/OpenFOAM-1.2/src/cfdTools/general/lnInclude -I/home/erik/OpenFOAM/OpenFOAM-1.2/src/turbulenceModels -I/home/erik/OpenFOAM/OpenFOAM-1.2/src/transportModels -I/home/erik/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxGcc4Opt/fluxSimpleFoam.o
TT.H: In function 'int main(int, char**)':
TT.H:48: error: no match for 'operator*' in 'Foam::operator*(const Foam::dimensioned<foam::scalar>&, const Foam::dimensioned<type>&) [with Type = Foam::scalar](((const Foam::dimensioned<foam::scalar>&)((const Foam::dimensioned<foam::scalar>*)(& Cp)))) * mesh. Foam::fvMesh::V()'
/home/erik/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/dimensionSet.H:194: note: candidates are: Foam::dimensionSet Foam::operator*(const Foam::dimensionSet&, const Foam::dimensionSet&)
/home/erik/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/dimensionedScalar.H:58: note: Foam::dimensionedScalar Foam::operator*(const Foam::dimensionedScalar&, Foam::scalar)
/home/erik/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/FieldFunctions.C:676: note: Foam::tmp<foam::field<type> > Foam::operator*(const Foam::UList<foam::scalar>&, const Foam::UList<t>&) [with Type = Foam::scalar]
/home/erik/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/FieldFunctions.C:678: note: Foam::tmp<foam::field<type> > Foam::operator*(const Foam::tmp<foam::field<foam::scalar> >&, const Foam::UList<t>&) [with Type = Foam::scalar]
/home/erik/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/FieldFunctions.C:777: note: Foam::tmp<foam::field<type> > Foam::operator*(const Foam::scalar&, const Foam::UList<t>&) [with Type = Foam::scalar]
/home/erik/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/tensorField.H:53: note: Foam::tmp<foam::vectorfield> Foam::operator*(const Foam::tmp<foam::tensorfield>&)
/home/erik/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/tensorField.H:56: note: Foam::tmp<foam::tensorfield> Foam::operator*(const Foam::tmp<foam::vectorfield>&)
/home/erik/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/dimensionedTensor.H:70: note: Foam::dimensionedVector Foam::operator*(const Foam::dimensionedTensor&)
/home/erik/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude/dimensionedTensor.H:73: note: Foam::dimensionedTensor Foam::operator*(const Foam::dimensionedVector&)
make: *** [Make/linuxGcc4Opt/fluxSimpleFoam.o] Error 1
Could anybody please give me a hint in order to get this right?
Thanks
/Erik
Old   May 29, 2006, 06:23
Default It seems as I need to definate
newbee
It seems as I need to definate the scalar * matrix operation differently from mesh.V()*q.
Does anyone know how to make this calculation?
Thanks
Erik
LinearInterpolaterhoU amp meshSf exact meaning arkangel OpenFOAM Running, Solving & CFD 2 August 21, 2007 05:29
