-   -   CrankNicholson errors (http://www.cfd-online.com/Forums/openfoam-solving/60200-cranknicholson-errors.html)
lr103476 October 21, 2005 10:40
Consider the movingCone case w
Consider the movingCone case with the solver icoFoamAutoMotion.
When using the second order CrankNicholson time integration I get an error message after the first mesh update.
FOAM FATAL IO ERROR : attempt to read beyond EOF
From function ITstream::read(token& t)
in file db/IOstreams/Tstreams/ITread.C at line 70.
Later I also tried this scheme in the cavity problems, but with no succes.
Is someone actually using this scheme, or am I doing something wrong.
Frank
hjasak October 21, 2005 10:47
There has been a change in the
There has been a change in the format that is not reflected in the config files. Add 0.5 after CrankNicholson (now the factor is run-time selectable):
ddtSchemes
default CrankNicholson 0.5;
Enjoy,
Hrv
maka May 21, 2006 13:07
shouldn't be CrankNicholson 1?
in the user guide:
4.4.6 Time schemeshttp://www.opencfd.co.uk/openfoam/do...#x20-1050004.4
it says:
There is an off-centering coefficient y with the CrankNicholson scheme that blends it with the the Euler scheme. A coefficient of y = 1 corresponds to pure CrankNicholson and and y = 0 corresponds to pure Euler. The blending coefficient can help to improve stability in cases where pure CrankNicholson are unstable.
best regards,
Maka
mattijs May 22, 2006 07:01
Sorry, I don't understand. Wha
Sorry, I don't understand. What shouldn't be 1?
(I only see some duplicate 'the the' and 'and and' in that section)
maka May 22, 2006 09:46
I mean that the previous messa
I mean that the previous message seemed to suggest that: a pure CrankNicholson scheme is applied in OpenFOAM by setting:
ddtSchemes
while the help in the user guide seems to says that it is:
ddtSchemes
default CrankNicholson 1;
which is right?
Many thanks,
Maka
hjasak May 22, 2006 21:00
You should be able to find thi
You should be able to find this out by looking at the source code:
/finiteVolume/ddtSchemes/CrankNicholsonDdtScheme/CrankNicholsonDdtScheme.H
//- Off-centering coefficient, 1 -> CN, less than one blends with EI
scalar ocCoeff_;
Need I say more? :-)
Hrv
lr103476 May 23, 2006 03:21
So a factor of 1 corresponds t
So a factor of 1 corresponds to fully second order Crank-Nicholson? I thought it should be 0.5?
Is this changed in OpenFOAM version 1.3
Frank
maka May 23, 2006 06:17
CrankNicholsonDdtScheme.C chan
CrankNicholsonDdtScheme.C changed between V 1.2 and 1.3 but I have no clue if the behavior changed. I'm still using V 1.2 and have been running a one-month simulation assuming it should be CrankNicholson 0.5 as the early post suggested. Do not ask me what is right and what is wrong. All I can say, enjoy :-)
/Maka
lr103476 May 24, 2006 10:23
Could someone please explain t
Could someone please explain the differences (if any) between v1.2 and v1.3.
Conform the theory books, a value of 0.5 would makes more sense then 1.0.
Frank
mattijs May 25, 2006 05:22
No basic differences between 1
No basic differences between 1.2 and 1.3.
maka May 26, 2006 03:14
Many thanks Mattijs for your c
Many thanks Mattijs for your clear reply.
/Maka.
lr103476 May 29, 2006 03:58
So for the record, Crank Nicho
So for the record, Crank Nicholson 1.0 corresponds to fully second order accuracy, while a value less then 1.0 is less accurate.
Sorry to bother you again, but I am not really into the theory at this moment.
Frank
openfoammaofnepo October 20, 2013 06:21
Hi All,
When I choose CN, but set the factor to 1. The pressure is very prone to blow up, which lead to the simulation failure. Could anyone tell me what is the reason for this problem? Thank you very much.
scalar ocCoeff_;
Hrv
