-   -   Boundary conditions for the LRR model (http://www.cfd-online.com/Forums/openfoam-solving/60221-boundary-conditions-lrr-model.html)
andimb May 9, 2006 11:30
Hi! How do I define the bou
Hi!
How do I define the boundary conditions for the LRR turbulence model at an inlet, an outlet and a wall?
Is this right?
inlet:
R_ii = 2/3*k
R_ij = 0 i<>j
outlet:
zero gradient
wall:
zero gradient
Thanks
Andreas
s.m October 16, 2013 03:43
Originally Posted by andimb (Post 183422)
Hi!
Is this right?
inlet:
R_ii = 2/3*k
R_ij = 0 i<>j
outlet:
zero gradient
wall:
zero gradient
Thanks
Andreas
Hi Andreas
i am simulatinf the flow over an airfoil, i use simpleFoam and LRR turbulence model, but my simulation with this model diverged, i don't know why!
did you understand How to define the boundary conditions for the LRR turbulence model at inlet &outlet &wall?
bgraves November 1, 2013 15:55
Hi S.M
if your simulation is diverging, what you can try is to run k-epsilon for 1000 iterations, then run the R command in terminal. Then go to RAS properties and change k-epsilon to LRR.
At the wall with a wall resolved grid the Reynolds stress tensor should be zero. At the inlet I use fixedValue and zeroGradient at the outlet.
Hope this helps,
-Ben
s.m November 4, 2013 06:42
Originally Posted by bgraves (Post 460167)
Hi S.M
Hope this helps,
-Ben
Ok, i 'll do it Ben.
Thank you very much:)
