March 20, 2006, 18:38 |
Hi all,
I got error message w
Guoxiang
Rep Power: 17 |
Hi all,
I got error message when I run buoyantFoam case without div(phi, U) term in UEqn as follows. Could anybody help me please? Thanks a lot. Starting time loop Mean and max Courant Numbers = 0 0 Time = 0.025 --> FOAM FATAL IO ERROR : Unknown symmetric matrix solver BICCG Valid symmetric matrix solvers are : 4 ( ICCG GaussSeidel DCG AMG ) file: /home/liu/OpenFOAM/liu-1.2/run/tutorials/buoyantFoam/hotRoom/system/fvSolution:: U at line 30. From function lduMatrix::solver::New(const fvMesh&, Istream&) in file matrices/lduMatrix/lduMatrixSolver.C at line 100. FOAM exiting |
March 21, 2006, 01:57 |
First, this subject applies to
Niklas Nordin
Rep Power: 29 |
First, this subject applies to almost EVERY discussion in this forum. So it does not describe
your problem very well, does it. I feel like a broken record, but pleeease choose a topic that describes your problem. second, you have posted the answer yourself, it is in the error message. It cannot be any clearer. N |
March 21, 2006, 03:54 |
Dear Guoxiang,
your "title"
VVqf
Rep Power: 17 |
Dear Guoxiang,
your "title" problem really puzzle us for a long time. I cant agree more with Niklas. Do please choose a suitable title for your post. Do the fovor for both you and us. The title I would suggest for your post might be "what solver for a symmetric matrix", or simplely "FOAM FATAL IO ERROR : Unknown symmetric matrix solver BICCG". The message means you should not use BICCG solver but ICCG for your case setting. clearly described in your own message: Valid symmetric matrix solvers are : 4 ( ICCG GaussSeidel DCG AMG ) in the FoamX: go to fvSolution -> solvers to change it. |
March 21, 2006, 06:23 |
fvSolution -> solvers -> U
VVqf
Rep Power: 17 |
usually you dont have such problem if you run the case with the solver default settings. did you copy the case from one solver to another? or you are modifying the codes, implementing another equation inside the code? |
March 21, 2006, 10:19 |
Thanks for your adice. I got i
Guoxiang
Rep Power: 17 |
Thanks for your adice. I got it.
Guoxiang |
How to solve injector problem | raj | FLUENT | 1 | March 12, 2007 11:13 |
How can I solve this problem? | Lee | Siemens | 2 | September 8, 2003 05:17 |
Help me to solve this problem !!! | kevin -Chang | FLUENT | 3 | November 24, 2002 00:43 |
Help me to solve this thorny problem | Kevin_chang | FLUENT | 1 | November 24, 2002 00:43 |
Can phoenics solve such problem? | Ning Yang | Phoenics | 2 | December 13, 2000 15:29 |
