-   -   Is there any tutorials about rotating machineturbomachinery such as pump etc (http://www.cfd-online.com/Forums/openfoam-solving/60292-there-any-tutorials-about-rotating-machineturbomachinery-such-pump-etc.html)
andycong March 2, 2006 05:26
Hi, I start a simulation which
Hi, I start a simulation which has a rotating zone, but I don't know what can do this in FOAM, could anyone help me?
Best Regards.
gschaider March 7, 2006 05:58
I'd suggest you check out thes
I'd suggest you check out these threads (the search function of the MessageBoard might give you further hints):
http://www.cfd-online.com/OpenFOAM_D...ges/1/770.html
http://www.cfd-online.com/OpenFOAM_D...es/1/1701.html
hani March 7, 2006 06:10
Hi Andy, If you are looking
Hi Andy,
If you are looking for a tutorial on rotor-stator interaction, have a look at icoTopoFoam, mixer2D.
If you only want to compute the flow in a rotating reference frame, add something similar to the following to a suitable solver:
dimensionedVector Omega
"Omega",
dimensionSet(0, 0, -1, 0, 0),
vector(0, 2*M_PI/60*(-595), 0) //The last number is RPM
// Calculate the centrifugal force
volVectorField Fcent = (Omega ^ (Omega ^ mesh.C()));
tmp<fvvectormatrix> UEqn
fvm::div(phi, U)
+ turbulence->divR(U)
+ (2*Omega ^ U) // Coriolis force
+ Fcent // Centrifugal force, computed ONCE above
Håkan.
andycong March 7, 2006 09:29
Thank you for your reply. And
And I think I am looking for the rotor-stator interaction.
