-   -   Combining interFoam amp simpleFoam (http://www.cfd-online.com/Forums/openfoam-solving/60299-combining-interfoam-amp-simplefoam.html)
kumar2 March 3, 2006 21:57
Dear Dr. Henry Weller 1. I
1.
I am studying flow over a hydrofoil. From looking at the interFoam results i got the feeling that the solver does not solve the viscous terms ( for example i was not able to see the wake behind the hydrofoil ) . Is this correct ?
2. How difficult is combining say interFoam & simpleFoam solvers ( I am new to OpenFOAM)
Thanks a lot
Best regards
Kumar
kumar2 March 4, 2006 19:36
Hello all , 1. I have a su
Hello all ,
1.
I have a suggestion for combining the interFoam and turbFoam . Took a look at the "UEqn.H" in the interFoam solver . noticed that the term for turbulence is absent. i was wondering if this term could be added - as in turbFoam.
2. If the modification is indeed possible , then what happens to the
solve(UEqn == -fvc::grad(p) ? Is this term simply taken care by the following in UEqn.H
if (momentumPredictor)
solve
UEqn
Can Dr. Henry Weller or anyone else please please give some inputs ?
Thanks a lot
Kumar
pierre March 5, 2006 10:03
Hello Kumar I think that wh
Hello Kumar
I think that what you're trying to do is already provided in OpenFoam, i.e. rasInterFoam. It is based on a PISO pressure-velocity coupling algorithm. You can try if you wish to change to it SIMPLE.
kumar2 March 5, 2006 16:38
Hi Pierre Thanks a lot for
Hi Pierre
Thanks a lot for the information.
I will check it out.
Best regards
Kumar
