Could anyone give me a LES simulation step by step
Old   February 7, 2006, 21:33
Default Because I am very new in CFD a
Andy Cong
andycong is on a distinguished road
Because I am very new in CFD and Foam, now my thesis is about the CFD,so I want somebody's help.
Thanks
andycong is offline   Reply With Quote
Old   February 8, 2006, 02:46
Default What do you mean? Do you want
Fabian Peng Karrholm
fabianpk is on a distinguished road
What do you mean? Do you want a finished LES simulation and look at the solution at each step? Or do you want someone to take you through what a solver for LES problems like coodles does?
If the case is the former, I suggest a tutorial (OpenFOAM/OpenFOAM-1.2/tutorials/oodles), if the case is the latter, I suggest a course in CFD, and THEN a course in turbulence and LES. Or you could read a book, I would recommend "Computational Methods for Fluid Dynamics" by Ferziger and Peric. Or the more basic, "An introduction to Computational Fluid Dynamics" by Versteeg and Malalasekera.
/Fabian
fabianpk is offline   Reply With Quote
Old   February 8, 2006, 03:23
Default Fabian has given very good sug
VVqf
vvqf is on a distinguished road
Fabian has given very good suggestions.
in addition:
for LES solver, take a look at page U-85 in Foam UserGuide, there's short description.
OpenFOAM/OpenFOAM-1.2/tutorials/oodles - incompressible
OpenFOAM/OpenFOAM-1.2/tutorials/coodles - compressible
CFD - turbulence modeling - LES
"Turbulence Modeling for CFD" by DC Wilcox
free:
http://personalpages.manchester.ac.uk/staff/david.d.apsley/lectures/comphydr/ind ex.htm
http://www.tfd.chalmers.se/~lada/pos...ndium_turb.pdf
PS:
If you could state your problem clear and specific in the future, it would help the others give you better help.
Qiufang
vvqf is offline   Reply With Quote
Old   February 8, 2006, 04:00
Default Well, if someone should be pro
Well, if someone should be promoting chalmers material, it's us who work here If you like the one above by Prof. Lars Davidson about turbulence models (simple k-epsilon and RSM models), go on and read the ones on LES on:
http://www.tfd.chalmers.se/doct/comp...ure_notes.html
/Fabian
Old   February 13, 2006, 21:17
Default Very Thanks, Now I will follow
Andy Cong
Very Thanks, Now I will follow your suggestion.
Thanks again.
If some problems, please allow me to bother you again.
Running code step by step sunnysun OpenFOAM Running, Solving & CFD 1 June 2, 2008 06:17
running gambit journal step by step giogio FLUENT 1 March 10, 2008 14:03
step simulation Bernardo Aflalo Phoenics 0 March 29, 2006 17:22
define moving mesh for engine step by step homan FLUENT 0 October 26, 2005 03:27
Backward-facing step simulation Keith Main CFD Forum 3 December 17, 2003 01:14
