-   -   How to update polyPatchbs localPoints (http://www.cfd-online.com/Forums/openfoam-solving/60361-how-update-polypatchbs-localpoints.html)
liu December 28, 2005 19:11
My mesh is moving at each time
My mesh is moving at each time step and I want to get the point coordinates on some polyPatch.
When I use mesh.readUpdate, polyPatch's localPoint is not updated? I am wandering how I can force this update operation.
Thank you!
hjasak December 28, 2005 19:26
You are doing something wrong:
- polyMesh.readUpdate cals clearGeom on line 313 in polyMeshIO.C
- polyMesh::clearGeom calls the clear or boundary patches arond line 232 in clearPolyMesh.C
- polyPatch.clearGeom comes from the primitiva patch, file PrimitivePatchClear.C, line 49
which deletes the pointer to local points. Thus, after you do readUpdate, the local points in the patch will be recalculated by force.
My guess is that you're either making a local copy somewhere along the way or thet you've messed about with my clear functions. Try switching on the primitive patch, poly patch and polyMesh debug flags and you should get some messages about recalculated local points.
Please keep me posted, I need to be 100% sure that the code is OK.
Hrv
liu December 28, 2005 19:58
Well, I tried to set some debu
Well, I tried to set some debug switch. But I don't know how to set "debug" for PrimitivePatch like below. Simply adding one entry in controlDict of foam gives segment fault.
void PrimitivePatch<face,>::clearGeom()
if (debug)
Info<<>::clearGeom() : "
<< "clearing geometric data"
<< endl;
deleteDemandDrivenData(localPointsPtr_);
deleteDemandDrivenData(faceNormalsPtr_);
deleteDemandDrivenData(pointNormalsPtr_);
hjasak December 28, 2005 20:23
In ~/.OpenFOAM-1.2/controlDict
set
PrimitivePatch 1;
in the DebugSwitches section.
Hrv
liu December 30, 2005 16:09
I found that the problem maybe
I found that the problem maybe is caused by that in PrimitivePatch.H
private:
// Private data
//- Reference to global list of points
PointField points_;
This part says it has a reference to the global list of points. But actually it is a copy of the global points and it's not updated anywhere. Unfortunately, everything are "recalculated" on this un-updated data.
Correct me if I am wrong.
hjasak December 30, 2005 16:31
You're wrong :-) Look what
You're wrong :-)
Look what it says:
template<class> class FaceList, class PointField>
class PrimitivePatch
This means that PointField is a third template argument for a PrimitivePatch. This is done so that the primitive patch machinery can take either a local point list or a reference to something else. Thus, a definition of a primitivePatch (the one polyPatch is derived from) is:
typedef PrimitivePatch<face,>
primitivePatch;
Finally:
class polyPatch
public patchIdentifier,
public primitivePatch
As you can see, the third template argument is const pointField& and all is well.
Anyway, I am 100% certain this stuff is OK beucase there's a ton of stuff that relies to it. I would advise looking at the code that's using it instead.
Good hunting,
Hrv
P.S. Did you get the messages from PrimitivePatch debug to see if the stuff is recalculated as I've suggested? Like I did :-) Take a CAREFUL look at how the recalculation of localPoints happens every time I ask for it.
wooster*143-> magU .. movingCone
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.2 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : magU .. movingCone
Date : Dec 30 2005
Time : 20:31:45
Host : wooster
PID : 31029
Root : ..
Case : movingCone
Nprocs : 1
Create time
Create mesh for time = 0.000000e+00
void polyMesh::calcFaceCells() : calculating faceCells
PrimitivePatch<face,>::calcFaceNormals() : calculating faceNormals in PrimitivePatch
PrimitivePatch<face,>::calcFaceNormals() : finished calculating faceNormals in PrimitivePatch
Time = 0.000000e+00
polyMesh::readUpdateState polyMesh::readUpdate() : Updating mesh based on saved data.
Cells instance: old = "constant" new = "constant"
Points instance: old = "constant" new = "constant"
No change
PrimitivePatch<face,>::calcLocalPoints() : calculating localPoints in PrimitivePatch
PrimitivePatch<face,>::calcMeshData() : calculating mesh data in PrimitivePatch
PrimitivePatch<face,>::calcMeshData() : finished calculating mesh data in PrimitivePatch
PrimitivePatch<face,>::calcLocalPoints() : finished calculating localPoints in PrimitivePatch
Reading U
Calculating magU
mag(U): max: 0 min: 0
Time = 1.000000e-05
Points instance: old = "constant" new = "1.000000e-05"
Point motion
void polyMesh::clearGeom() : clearing geometric data
PrimitivePatch<face,>::clearGeom() : clearing geometric data
Reading U
Calculating magU
mag(U): max: 3.41646 min: 0.00140977
Time = 5.000000e-05
Points instance: old = "1.000000e-05" new = "5.000000e-05"
Point motion
Reading U
Calculating magU
mag(U): max: 3.27453 min: 0.000860374
End
void polyMesh::clearAddressing() : clearing topology
PrimitivePatch<face,>::clearTopology() : clearing patch addressing
PrimitivePatch<face,>::clearPatchMeshAddr() : clearing patch-mesh addressing
liu December 30, 2005 18:27
sorry guys, I made a mistake i
sorry guys, I made a mistake in my own code.
Now it's clear.
Happy new year!
