December 22, 2005, 01:54 |
I am evaluating op
frederic.deghetto@free.fr
Rep Power: 17 |
I am evaluating openFoam for an industrial use. I am calculating the flow at engine outlet, between the turbine outlet and the silencer. For that purpose, I have selected the sonicTurbFoam solver. With the following initial and boundary conditions: Initial conditions -Inside flow: velocity 0, pressure 1 bar, temperature 643°K, k=1000, epsilon=25000 Boundary conditions - Inlet velocities 80m/s, inlet k 1000, inlet epsilon 25000, inlet temperature 643°K. The cfl number is, of course, less than 1. And after 6 days on a bi-opteron 64 bits, the case has reached 0.5 second. All informations are very well calculated. I compared the wave effects with the results of a 1D tool and the results are very closed. But I would like to increase the time step to reduce the calculation time. What do you suggest me ? Is it a good idea to change the time scheme to backward ? Is it necessary to select an other solver ? Thank you Frederic |
time step calculation | david | FLUENT | 1 | May 7, 2008 01:36 |
How to improve solution time for the SonicTurbFoam app | shaun | OpenFOAM Running, Solving & CFD | 2 | May 11, 2007 03:34 |
time of calculation with a bi processor | sam | FLUENT | 9 | July 25, 2005 04:48 |
Time calculation | luca | FLUENT | 2 | November 25, 2004 04:21 |
time calculation | shami | FLUENT | 0 | October 25, 2004 03:03 |
