how can I use temperatu
how can I use temperature-dependent material properties in OpenFOAM given as ASCII data for thermal conductivity, viscosity at specific temperatures ? Is there a simple way to read in this data ? Thanks, Juergen |
You will need to write some co
You will need to write some code for it yourself. If you want to use straight interpolation between your data points, there's the "interpret graph" stuff - should be described in the manual.
However, the thermodynamicalProperties library contains a lot of pre-packaged temperature- and pressure-dependent material properties for liquids and gasses. Unless you're doing something pretty exotic, the chance is that the data (e.g. JANAF tables or similar) is already there, ready to use. Enjoy, Hrv |
Sorry, but I can't find any "i
Sorry, but I can't find any "interpret graph" stuff in the manual.
Actually, I wanted to modify the laplacianFoam/flange example to use a temperature-dependent thermal conductivity for the solid, given as temperature/data pairs. How can I change the scalar variable DT to represent thermal conductivity which is linear interpolated between the data points: ... solve ( fvm::ddt(T) - fvm::laplacian(DT, T) ); ... Gas or liquid properties are not applicable here. Thanks, Juergen |
Heya,
In that case, you wil
Heya,
In that case, you will need to make a field DT and fill it in yourself using the values form the lookup table. Two things for you: An example for the interpolation part from the graph (i.e. you give me a graph and an x and I give you a value) can be found in: OpenFOAM-1.1/src/engine/engineValve have a look at: engineValve.C, line 174: Foam::scalar Foam::engineValve::lift(const scalar theta) const return interpolateXY ( adjustCrankAngle(theta), liftProfile_.x(), liftProfile_.y() ); Here, I calculate the crank angle such that it falls between the ends of the graph and then "read off" the graph value using interpolateXY. InterpolateXY lives in the sampling library in src. Yo can also find examples on how I read in the graph etc in the same class. The second bit yo need is to make a field and fill it in with values. It's is done like this (below). In this function I make a temporary field and fill it with values of brick_.cpVapour - instead of this, you will be using interpolateXY. If you wish, you can make and fill in the field straight in the main code, avoiding the function and all this tmp field stuff. Enjoy, Hrv Foam::tmp<foam::volscalarfield> Foam::brickState::cpVapour() const { tmp<volscalarfield> tcpVapour ( new volScalarField ( IOobject ( "cpVapourTmp", mesh_.time().timeName(), mesh_, IOobject::NO_READ, IOobject::NO_WRITE ), mesh_, dimSpecificHeatCapacity ) ); volScalarField& cp = tcpVapour(); scalarField& cpInternal = cp.internalField(); const scalarField& TInternal = T_.internalField(); forAll (cpInternal, cellI) { cpInternal[cellI] = brick_.cpVapour(TInternal[cellI]); } forAll (cp.boundaryField(), patchI) { scalarField& patchCp = cp.boundaryField()[patchI]; const scalarField& patchT = T_.boundaryField()[patchI]; forAll (patchCp, faceI) { patchCp[faceI] = brick_.cpVapour(patchT[faceI]); } } return tcpVapour; } |
Dear All:
Could you help me
Dear All:
Could you help me see my code and errors. I do know what is wrong in it. Please give some advice. // set the nu for each cell 116: volScalarField& nuInternal = nu.internalField(); forAll (nuInternal, celli) { if (componentValue[celli] > 0) nuInternal[celli] = 0.3; else nuInternal[celli] = 0.1; } // set the rho for each cell 125: volScalarField& rhoInternal = rho.internalField(); forAll (rhoInternal, celli) { if (componentValue[celli] > 0) rhoInternal[celli] = 2000000; else rhoInternal[celli] = 20000; } // set the E for each cell 134: volScalarField& EInternal = E.internalField(); forAll (EInternal, celli) { if (componentValue[celli] > 0) EInternal[celli] = 7854; else EInternal[celli] = 1000; } Error as: stressedFoam.C:116: error: 'struct Foam::dimensionedScalar' has no member named 'internalField' stressedFoam.C:125: error: 'struct Foam::dimensionedScalar' has no member named 'internalField' stressedFoam.C:134: error: 'E' was not declared in this scope stressedFoam.C:134: error: '<typeprefixerror>E' previously declared here Thanks deeply, Guoxiang |
has anyone done something like descibed above? I could need a temperature dependant viscosity (probably also conductivity)! (with topological changes...) Thanks Marco |
This thread is quite old, I know. For anyone crossing this while looking for "how to implement temperature dependent thermophysical properties and interpolate them on the mesh": the answer is given in this post:
http://www.cfd-online.com/Forums/ope...ies-false.html Have fun, Anja |
