DieselFoam and temperature out of janaf range
Like Tree1Likes
  • 1 Post By lucchini
Old   July 14, 2007, 07:14
Default I'm trying to use dieselFoam (
Jason Hoogland
hoogland is on a distinguished road
I'm trying to use dieselFoam (for the excellent particle tracking) to model the injection of gas and particles from a reservoir containing ambient air @ 20 [atm] into a 20 [L] spherical chamber with initial ambient air @ 0.4 [atm]. Flow at the inlet is expected to be 2 > M > 1. I've done this already in Fluent.
Using many of the defaults from aachenBomb (e.g. chem.inp, therm.inp and dict files), I have switched on the PISO transonic option. With chemistry, turbulence and virtually all the particle models switched off, after a few hundred iterations, a temperature somewhere creeps below the thermo table lower limit of 200 [K], e.g.:
\start
Evolving Spray
Solving chemistry
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 2.82412e-05, Final residual = 1.52958e-09, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 2.56321e-05, Final residual = 5.48701e-09, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 2.2131e-05, Final residual = 2.16408e-09, No Iterations 1
DILUPBiCG: Solving for C7H16, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for O2, Initial residual = 7.56145e-05, Final residual = 1.06866e-08, No Iterations 1
DILUPBiCG: Solving for CO2, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for H2O, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for h, Initial residual = 6.94819e-05, Final residual = 6.86817e-09, No Iterations 1
DILUPBiCG: Solving for p, Initial residual = 4.17584e-08, Final residual = 2.10339e-13, No Iterations 1
time step continuity errors : sum local = 1.58205e-16, global = 6.99217e-19, cumulative = 6.87049e-15
DILUPBiCG: Solving for p, Initial residual = 5.92624e-12, Final residual = 5.92624e-12, No Iterations 0
time step continuity errors : sum local = 1.69901e-16, global = 6.65534e-19, cumulative = 6.87116e-15
Number of parcels in system | 1442
Injected liquid mass....... | 4.58556e-10 mg
Liquid Mass in system...... | 194.444 mg
SMD, Dmax.................. | 105.083 mu, 563.588 mu
Added gas mass = -194.444 mg
Evaporation Continuity Error| 6.37119e-06 mg
ExecutionTime = 2201.73 s ClockTime = 2201 s
Courant Number mean: 1.52092e-06 max: 0.00999747
deltaT = 7.18861e-09
Time = 4.59275e-06
Evolving Spray
Solving chemistry
DILUPBiCG: Solving for Ux, Initial residual = 2.81661e-05, Final residual = 1.52641e-09, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 2.56031e-05, Final residual = 5.43359e-09, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 2.20784e-05, Final residual = 2.1833e-09, No Iterations 1
[1]
[1]
[1] --> FOAM FATAL ERROR : attempt to use janafThermo<equationofstate> out of temperature range 200 -> 5000; T = 199.958#0 Foam::error::printStack(Foam:stream&)
#1 Foam::error::abort()
#2 Foam::specieThermo<foam::janafthermo<foam::perfect gas> >::H(double) const
#3 Foam::hMixtureThermo<foam::reactingmixture>::calcu late()
#4 Foam::hMixtureThermo<foam::reactingmixture>::corre ct()
#5 main
#6 __libc_start_main
#7 __gxx_personality_v0 at ../sysdeps/x86_64/elf/start.S:116
[1]
[1]
[1] From function janafThermo<equationofstate>::checkT(const scalar T) const
[1] in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.4/src/thermophysicalModels/specie/lnInclude/ janafThermoI.H at line 73.
[1]
FOAM parallel run aborting
\end
David Herbert addressed similar issues in http://www.cfd-online.com/cgi-bin/Op...cus/discus.cgi, . I suspect there is a fundamental mathematical/numerical issue going on with the thermo parameters, maybe in combination with the relatively high level of expansion occuring in the gas. I have some additional questions:
- If I have switched chemistry off, why are many of the species still involved in the calculation (see output above)?
- What is the best way to find out which cell(s) are approaching a given parameter threshhold, in this case T = 200 [K]? It would help with diagnosis.
- How can I switch the calculation of thermo parameters over from the curve fits to constant and/or perfect gas properties?
Cheers
Jason
hoogland is offline   Reply With Quote
Old   July 15, 2007, 04:53
Default Dear Jason, the crashing of
Tommaso Lucchini
lucchini is on a distinguished road
Dear Jason,
the crashing of dieselFoam and the other combustion solvers is generally linked to troubles related to numerics or bad mesh resolution (non-orthogonality or skew).
These are some suggestions to improve your case:
First of all, switch all the Laplacian schemes to
Gauss linear uncorrected or
Gauss linear limited and see what happens,
Second: try upwind schemes for the enthalpy in divSchemes
Third, make sure about the mesh generation, where everything which is a "real wall" must be declared as a wall (and not a patch) in the blockMeshDict file and in the boundary file.
Fourth, try with a finer mesh
Fifth: try to increase the number of correctors in the PISO settings.
Then, the replies to your questions:
1) Switching the chemistry off means that no chemical source terms will be calculated. Even if you switch the chemistry off, the number of the involved species is always same since it taken from the chemical mechanism and for this reason for each species a transport equation is solved.
2) Have a look at the thermo->correct() function which should be in the hMixtureThermo class and see where the temperature is re-calculated after the enthalpy equation.
3) with dieselFoam you can only use reactingMixture and janafThermo, if you want to use something else you have to re-write your own solver and in this case you can use a multiComponentMixture with hConstThermo (which should be perfect gas)
That's all.
Regards
Tommaso
justsmile2007 likes this.
lucchini is offline   Reply With Quote
Old   July 17, 2007, 21:19
Default Thanks Tommaso, That was he
Jason Hoogland
Thanks Tommaso,
That was helpful. Have tried all but the finer mesh without success. The original mesh was tet but I also tried with a wedge hex and paved hex mesh. Looks like I'll have to hack the solver.
I've had this problem before using an "in-house" c code with full chemkin-like chemistry which works well at elevated temperatures - what it is designed for - but falls over for room and sub-room temperatures in the presence of compressible flow expansion. I'd like to figure out why some day!
Jason
Old   May 6, 2009, 14:10
Nugroho Adi
mahaputra is on a distinguished road
Originally Posted by hoogland View Post
Thanks Tommaso,
Jason
Hi Jason Hoogland
did you succeess with your dieselFoam simulation?
i got a same problem same as yours.
please let me know how you fixed it.
thanks
mahaputra is offline   Reply With Quote
Old   December 9, 2009, 10:04
Ilja Sabelfeld
hamburgFoam is on a distinguished road
HeyNugroho,
i have the same problem like you. i am using the reactingFoam solver.
attempt to use janafThermo<equationOfState> out of temperature range 200 -> 5000; T = 194.657#0 Foam::error:rintStack(Foam::Ostream&) in "/home/openfoam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/openfoam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::specieThermo<Foam::janafThermo<Foam:erfect Gas> >::H(double) const in "/home/openfoam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libreactionThermophysicalModels.so"
#3 Foam::hPsiMixtureThermo<Foam::reactingMixture<Foam ::sutherlandTransport<Foam::specieThermo<Foam::jan afThermo<Foam:erfectGas> > > > >::calculate() in "/home/openfoam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libreactionThermophysicalModels.so"
#4 Foam::hPsiMixtureThermo<Foam::reactingMixture<Foam ::sutherlandTransport<Foam::specieThermo<Foam::jan afThermo<Foam:erfectGas> > > > >::correct() in "/home/openfoam/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libreactionThermophysicalModels.so"
#5 main in "/home/openfoam/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/reactingFoam"
#6 __libc_start_main in "/lib/libc.so.6"
#7 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
From function janafThermo<equationOfState>::checkT(const scalar T) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 64.
FOAM aborting
could you let me know, how to fixe it?
regards,
ilja
hamburgFoam is offline   Reply With Quote
Old   January 28, 2016, 12:30
Roberto Ribeiro Schor
rrschor is on a distinguished road
I'm with the same error... with the dieselFoam from Extended 3.2...
Does someone knows how to fix this lowering of temperature?
rrschor is offline   Reply With Quote
Janaf Tables Mark Main CFD Forum 2 July 4, 2011 11:57
Inverted Janaf formula gianpaolo CFX 2 October 1, 2007 05:13
JANAF tangd OpenFOAM Running, Solving & CFD 12 July 26, 2006 04:26
About dieselFoam tsjb00 OpenFOAM Running, Solving & CFD 3 August 16, 2005 16:59
Residence time per temperature range Roman FLUENT 0 February 16, 2000 01:58
