October 19, 2005, 10:06 |
I'm having a problem generatin
Håkan Nilsson
Rep Power: 18 |
I'm having a problem generating a solution with the turbFoam solver, and I have been recommended to write an unsteady SIMPLE solver. Has anyone done this already?
My problem with the turbFoam solver can be that there is a big difference in Courant numbers throughout the mesh. Did anyone have any experience on this? I have tried two different quite different 3D cases with two different grids, for which I am able to get steady solutions using simpleFoam. Håkan. |
October 25, 2005, 05:23 |
Where can I find information o
Håkan Nilsson
Rep Power: 18 |
Where can I find information on the following:
(I have searched the forum and the manual, but I can of course have missed it) What is the difference between tmp<fvvectormatrix> UEqn; and fvVectorMatrix UEqn; The former occurs in simpleFoam and the latter occurs in turbFoam. In simpleFoam the UEqn is cleared after use (UEqn.clear();). Does this have anything to do with the difference? When running without the clear statement in simpleFoam I seem to run out of memory. Why is that not the case with fvVectorMatrix UEqn; in turbFoam? What are A() and H() in simpleFoam and turbFoam? Håkan. |
October 25, 2005, 11:17 |
Sorry, I see that some bracket
Håkan Nilsson
Rep Power: 18 |
Sorry, I see that some brackets are missing in the distributed e-mail for some reason. The complete message is however available in the forum.
I guess that someone knows the answers? Håkan. |
October 25, 2005, 13:43 |
tmp is just a container class
Mattijs Janssens
Rep Power: 26 |
tmp is just a container class to aid memory management for allocated objects.
Simple foam solver | mardinoglu | OpenFOAM Running, Solving & CFD | 1 | October 17, 2014 04:56 |
Simple 2d Matlab Solver | Gabriel Usera | Main CFD Forum | 7 | May 14, 2007 00:11 |
unsteady using SIMPLE algorithm | simple | Main CFD Forum | 3 | June 24, 2006 03:43 |
nUMECA UNSTEADY SOLVER | dimitris | Main CFD Forum | 1 | May 16, 2001 10:28 |
Does anyone work at SIMPLE in unsteady and compressibel flow | Junl | Main CFD Forum | 1 | February 4, 2000 21:24 |
