September 19, 2005, 15:45 |
Dear all,
I am using rhoTur
Daniele Panara
Rep Power: 17 |
Dear all,
I am using rhoTurbFoam for a pulsating channel application. The case consists of a heated pulsating air channel. If I start my computations directly using rhoTurbFoam the solver needs a really small time step in order to reach a stable solution. In order to obtain a faster solution I tought to initialize the field with a solution from turbFoam on the same cold pulsating channel. After the turbFoam case reached the convergence, I added the temperature field and tried to run the case under rhoTurbFoam. The dimension for the pressure and phi were wrong and I simply changed them... The calculation was anyway unstable and I got very soon nan values. did I make a mistake? Is that the right way to initialize the turbulent field from turbFoam to rhoTurbFoam? The flow is incompressible ( very low mach number ) and the problem is of forced-convection type.. (not strong buoyance effects). Is rhoTurbFoam the right solver? how can I improve its stability? any advice will be apreciated, regards, Daniele |
Display Modes | |
Turbulent compressible solver rhoTurbFoam with dynamic moving mesh | eno | OpenFOAM Running, Solving & CFD | 4 | December 12, 2011 04:38 |
RhoTurbFoam max number of iterations | jia_kok | OpenFOAM Running, Solving & CFD | 6 | July 3, 2009 06:03 |
RhoTurbFoam sonicFoam rhoSonicFoam | mwibmer | OpenFOAM Bugs | 2 | September 1, 2008 05:28 |
Problem: text commands to initialize flow field | Carolyn Jacobs | FLUENT | 0 | April 10, 2007 06:03 |
Putting submesh field values into field on parent mesh | helmut | OpenFOAM Running, Solving & CFD | 2 | June 20, 2006 08:31 |
