August 30, 2005, 04:04 |
It looks like in ver 1.2, tota
It looks like in ver 1.2, totalPressureInlet and inletOutlet bcs have been removed. In ver 1.1 at the inlet, three options were there, i.e. totalPressureInlet, inletOutlet, and pressureInlet. Now only pressureIlnet is available. Am I correct or something is wrong with my installation?
Regards GS |
August 30, 2005, 04:14 |
No boundary conditions have be
Rep Power: 22 |
No boundary conditions have been removed and some have been added. You will find the BC implementations in sub-directories of OpenFOAM-1.2/src/OpenFOAM/fields/fvPatchFields or in OpenFOAM-1.2/src/cfdTools/general/derivedFvPatchFields.
August 30, 2005, 04:24 |
Thanks Henry. I am just going
Thanks Henry. I am just going through the new version. Now at the "outlet" many more options are available and an extra "inletOutlet" category has been added in ver 1.2. This will be very usefull for external flows.
Thanks and regards GS |
August 30, 2005, 06:35 |
For k and epsilon wall BCs in
For k and epsilon wall BCs in ver 1.1 we had two options (a) k -> fixedValue, epsilon -> zeroGradient
(b) wall function (i.e. zero gradient for k and epsilon) These two options are still available in 1.2, but when I use option (a) I get following message: ------------------------------------------ --> FOAM FATAL ERROR : fixedValue is the wrong k patchField type for wall-functi ons on patch plate_wall should be zeroGradient From function wall-function evaluation in file /data/OpenFOAM/OpenFOAM-1.2/src/cfdTools/general/lnInclude/checkPatc hFieldTypes.H at line 3. FOAM exiting ------------------------------------------ It looks like it is forcing to use wall function. In case I do not want to use wall function what do I do? Regards GS |
August 30, 2005, 06:45 |
All high-Re turbulence models
Rep Power: 22 |
All high-Re turbulence models use wall-function of some kind because that is a requirement. For wall functions to work properly you must choose appropriate boundary conditions for the form of the implementation which in the case of OpenFOAM is zeroGradient on both k and epsilon. If you have been choosing otherwise your results will be wrong. To stop people making this error I have put in a check in 1.2.
If you don't want to use wall-functions choose a low-Re model with special near-wall modelling and run with a mesh fine enough in the near-wall region for it to be stable. There are several low-Re turbulence models to choose from. If you don't like either of these options there are two others, either run with slip walls or implement the model and boundary conditions you think is best for your purpose. |
August 30, 2005, 07:16 |
Thanks Henry for the clarifica
Thanks Henry for the clarification. I will prefer to go for realizable k epsilon model with a two layer approach near the wall. Which you know I have already implemented. I will test and see how it works with this version.
Regards GS |
August 30, 2005, 07:20 |
... and you should choose the
Rep Power: 22 |
... and you should choose the k-epsilon BCs that are appropriate for your implementation of the two layer approach which may not be a standard option in FoamX so you might have to either edit the k-epsilon files by hand and specify the BCs that way or add the options you require to the FoamX configuration files.
August 30, 2005, 07:44 |
Thats right. Basically it will
Thats right. Basically it will be same as the one for low Re models.
Regards GS |
OpenFoam vs CFX5 mass balance in OpenFoam | tangd | OpenFOAM Running, Solving & CFD | 33 | May 23, 2010 16:36 |
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 | martapajon | OpenFOAM Meshing & Mesh Conversion | 7 | January 21, 2008 12:52 |
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen | jaswi | OpenFOAM | 0 | August 3, 2007 13:11 |
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix | mbeaudoin | OpenFOAM Installation | 2 | April 28, 2006 08:54 |
How to set smoke inlet speed on inlet | Adam | FLUENT | 0 | October 4, 2005 08:18 |
