-   -   Error message disappears (http://www.cfd-online.com/Forums/openfoam-solving/60519-error-message-disappears.html)
ghanshyam August 17, 2005 02:03
I am using simpleFoam with kEp
I am using simpleFoam with kEpsilon model. After few iterations it looks like it stops solving equations of k and epsilon as I don't see error on my terminal. Does this mean that these equations diverged? How to make it visible all the time. I have experimented with "tolerences" as well as "relaxation factors" no improvement.
Regards
GS
liu August 17, 2005 02:07
Maybe the initial residual is
Maybe the initial residual is less than tolerences, so these equations don't need to be solved. Steady state?
ghanshyam August 17, 2005 02:10
Yes, steady state, I was guess
Yes, steady state, I was guessing the same, but I still want to solve. How do I do that.
Regards
henry August 17, 2005 04:30
Do you see the initial residua
Do you see the initial residual fall? Does it drop below your convergence tolerance? Have you tried making the convergence tolerance very tight?
ghanshyam August 17, 2005 04:40
Yes, initially there is reduction in residual.
Yes
Yes
Currently I am compiling the code by making following change in "tests.C"
//converged_ = true;
converged_ = false;
Will this help?
Regards
GS
henry August 17, 2005 04:53
I would be able to help you mo
I would be able to help you more if I had the answers to my questions or better still a section of the log file from just before k-epsilon stop solving to just after.
henry August 17, 2005 04:55
Sorry, I missed the answers bu
Sorry, I missed the answers buried there. Anyway, I would still like to see the section of log file. Have you looked the the field valeus for k-epsilon? Are they VERY large?
ghanshyam August 17, 2005 07:18
BICCG: Solving for Ux, Initia
BICCG: Solving for Ux, Initial residual = 0.0114222, Final residual = 0.000931753, No Iterations 1
BICCG: Solving for Uy, Initial residual = 0.0227955, Final residual = 0.00190204, No Iterations 1
BICCG: Solving for Uz, Initial residual = 0.00691902, Final residual = 0.000593082, No Iterations 1
ICCG: Solving for p, Initial residual = 0.0216008, Final residual = 0.000214944, No Iterations 116
time step continuity errors : sum local = 0.00871451, global = 0.000437168, cumulative = 0.0171293
BICCG: Solving for epsilon, Initial residual = 0.021943, Final residual = 2.2619e-08, No Iterations 1
BICCG: Solving for k, Initial residual = 1.78372e-05, Final residual = 1.1457e-06, No Iterations 1
ExecutionTime = 201 s
Time = 257
BICCG: Solving for Ux, Initial residual = 0.0114393, Final residual = 0.000938528, No Iterations 1
BICCG: Solving for Uy, Initial residual = 0.0228175, Final residual = 0.0019204, No Iterations 1
BICCG: Solving for Uz, Initial residual = 0.00691351, Final residual = 0.00059707, No Iterations 1
ICCG: Solving for p, Initial residual = 0.0229688, Final residual = 0.000222948, No Iterations 115
time step continuity errors : sum local = 0.00902571, global = 0.000449829, cumulative = 0.0175791
BICCG: Solving for epsilon, Initial residual = 0.0225105, Final residual = 2.18334e-08, No Iterations 1
bounding epsilon, min: -3.5104e-12 max: 822122 average: 4651.92
ExecutionTime = 205.23 s
Time = 258
BICCG: Solving for Ux, Initial residual = 0.0114469, Final residual = 0.00095594, No Iterations 1
BICCG: Solving for Uy, Initial residual = 0.0226974, Final residual = 0.00194632, No Iterations 1
BICCG: Solving for Uz, Initial residual = 0.00688176, Final residual = 0.000596608, No Iterations 1
ICCG: Solving for p, Initial residual = 0.0220571, Final residual = 0.00021926, No Iterations 118
time step continuity errors : sum local = 0.00883914, global = 0.000396233, cumulative = 0.0179754
Will this help to clarify myself? You can see after Time(iteration) # 257, k and epsilon disappears forever.
Regards
GS
henry August 17, 2005 07:27
What convergence tolerance hav
What convergence tolerance have you set for k and epsilon?
ghanshyam August 17, 2005 07:31
For both 1e-5(Tolerance), 0.1(
For both 1e-5(Tolerance), 0.1(RelativeTolerance)
henry August 17, 2005 07:35
For cases will wall-functions
For cases will wall-functions I use 1e-8.
ghanshyam August 17, 2005 07:38
Now I am running with 1e-15 an
Now I am running with 1e-15 and 0.1 for both. It appears again. This way what is the lower tolerence limit?
Thanks and regards
GS
henry August 17, 2005 07:43
Check the k and epsilon fields
Check the k and epsilon fields, it sounds like they are becoming VERY large which affecting the residual normalisation.
ghanshyam August 17, 2005 08:03
Max epsilon is 676404.2 m^2/s^
Max epsilon is 676404.2 m^2/s^3 and k is 72 m^/s^2, which is not too large value.
It has disappeared again even after giving tolerance 1e-15 for both k and epsilon.
Regards
GS
henry August 17, 2005 08:08
It appears k and epsilon have
It appears k and epsilon have converged for your case.
ghanshyam August 17, 2005 08:12
But I do not want it to stop s
But I do not want it to stop solving k and epsilon, as flow field is still developing. How do I do that?
Regards
GS
henry August 17, 2005 08:19
For some reason, probably due
For some reason, probably due to something in your setup/BCs, the k-epsilon system has converged and nothing you do to the tolerances will make it converge further. You need to find out what is wrong with your setup.
We would be happy to check and correct your case as part of your support contract with OpenCFD.
