NonNewtonianIcoFoam for steadystate problem
Old   July 18, 2005, 15:19
Default Hi, Henry, In one of the ea
Jing Wang
mpml is on a distinguished road
Hi, Henry,
In one of the earlier responses on this forum you said that transient solvers may not converge for steady-state problems. Right now I am trying to model some polymer extrusion process using OpenFOAM, but it looks like there is no solver for steady-state laminar flow of nonNewtonian fluids. Do you think nonNewtonianIcoFoam can be used for my purpose by setting the runTime long enough? (simpleFoam seems to be for turbulent flow, rather than laminar flow)
If you don't think so, could you explain a little bit what I should do? Thanks a lot.
mpml is offline   Reply With Quote
Old   July 18, 2005, 15:21
Default Use simpleFoam with the "lamin
henry is on a distinguished road
Use simpleFoam with the "laminar" turbulence model.
henry is offline   Reply With Quote
Old   July 19, 2005, 10:31
Default I want to patch, in the first
olivier Petit
olivier is on a distinguished road
I want to patch, in the first zone where y<1,
a viscosity wich is different than the one in the second zone where y>1.
How can i do that, please
Thanks a lot.
olivier is offline   Reply With Quote
Old   July 19, 2005, 14:56
Default Have a look at the setGammaDam
Mattijs Janssens
mattijs is on a distinguished road
Have a look at the setGammaDambreak utility in the damBreak tutorial on how to access the cell centres.
Change the createFields.H in your solver and make the nu into a volScalarField. Either use the same syntax as for e.g. p in which case it gets read from disk or use the extra constructor argument:
volScalarField nu
IOobject
"nu",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar(transportProperties.lookup("nu") )
mattijs is offline   Reply With Quote
Old   July 19, 2005, 15:32
Default Hi, Henry, Thanks for your
Jing Wang
Hi, Henry,
Thanks for your last reply. I tried simpleFoam and it got a converged solution for my problem. But the pressure seems about 2 orders lower than expected.
I am somehow confused about the PDE equation defined in simple foam, which is:
tmp<fvvectormatrix> UEqn
fvm::div(phi, U)
+ turbulence->divR(U)
UEqn().relax();
solve(UEqn() == -fvc::grad(p));
It seems the diffusion term, fvm::laplacian(fluid->nu(), U), doesn't appear here. I think it it included in the turbulence->divR(U) term, but can not figure it out by looking at the source code.
My question is, if I use laminar model in simpleFoam, are the PDEs in nonNewtonianIcoFoam and SimpleFoam going to be exactly the same (except for the time derivative) ? How does simpleFoam read in the transport properties(I don't see 'transportProperties.lookup("nu")' in simpleFoam's sourcecode) ? Thanks a lot.
Old   July 19, 2005, 15:39
Default simpleFoam should give very si
simpleFoam should give very similar results to nonNewtonianIcoFoam.
The laminar transport model is created by
autoPtr<transportmodel> laminarTransport
transportModel::New(U, phi)
in simpleFoam and equivalently by
autoPtr<transportmodel> fluid
in nonNewtonianIcoFoam,
dimensionedScalar nu
is redundant and should be removed.
The laminar stress term is indeed included in
turbulence->divR(U)
Old   July 20, 2005, 18:58
Default Thanks, Henry. I checked the s
Jing Wang
Thanks, Henry. I checked the source code and is much better informed now.
I have a very simple question (maybe stupid) about the following line of code:
fvc::div(nuEff( )*dev(fvc::grad(U)( ).T( )))
It looks like this is the momentum source, which is ignored in nonNewtonianIcoFoam. But I have never seen expressions like "grad(U)( )" in C++ code (a function call followed immediately by a pair of brackets). Is the return value from grad(U) used as a function name here?
Thanks a lot if you can clarify a little bit.
Old   July 20, 2005, 19:09
Default In incompressible flow that te
In incompressible flow that term will be small but only zero if the viscosity is uniform and hence formally should be included in nonNewtonianIcoFoam.
fvc::grad(U) returns a tmp<voltensorfield> and the transpose member function .T() is called for the const volTensorField& returned by the tmp dereferencing operator ().
Couette flow with nonNewtonianicoFoam floooo OpenFOAM Running, Solving & CFD 2 December 7, 2010 05:39
SteadyState tutlhino OpenFOAM Running, Solving & CFD 5 April 30, 2009 09:10
Steadystate settlingFoam darrin OpenFOAM Running, Solving & CFD 0 February 28, 2007 04:51
Steadystate Vs Transient solver amitshah OpenFOAM Running, Solving & CFD 1 August 23, 2006 02:54
Steadystate Euler solver jelmer OpenFOAM Running, Solving & CFD 1 June 19, 2006 08:24
