Computation in parallel
Old   June 29, 2005, 10:36
Default I do my job on a cluster of ma
zoujianfeng
zou_mo is on a distinguished road
Send a message via MSN to zou_mo
I do my job on a cluster of machines and I use LAM. It need a file 'machines'. The first line of this file is the machine I logged in. But the first machine of my cluster is always busy and the CPU rate of the first machine is low.
How to solve this problem?
zou_mo is offline   Reply With Quote
Old   June 29, 2005, 10:48
Default Since your working directory a
Eugene de Villiers
eugene is on a distinguished road
Since your working directory and the Foam installation have to be visible from all the machines, you can just log into one of the cluster nodes and start the job from there.
If this is a problem because of some batch queing system like pbs, you should submit the job via this system. I can provide an example script for pbs if required.
eugene is offline   Reply With Quote
Old   June 29, 2005, 11:08
Default Thanks for your help. I hav
zoujianfeng
I have just got help from my admin. I use 'rsh node#' to a empty node and run my case from there.
Thanks.
Parallel computation morfeus80 OpenFOAM Running, Solving & CFD 2 May 8, 2008 07:20
Parallel computation Jonas Pedro Caumo CFX 6 December 19, 2006 14:51
about parallel computation akang CFX 5 June 22, 2005 10:51
MPI and parallel computation Wang Main CFD Forum 4 April 3, 2005 06:40
MPI and parallel computation Wang Main CFD Forum 7 April 15, 2004 11:25
