November 23, 2022, 09:16 |
sprayFoam in openfoam9??
Matteo
Rep Power: 4 |
Hello, in openfoam 8 there is the solver "sprayFoam" that could be used for simulating the injection of gasoline and its mixing with the surrounding air before / after the throttle valve. I saw that in openfoam 9 there is no more. Is there a solver that can solve the same problem (maybe particleFoam) or is it better to stick with sprayFoam in openfoam 8?
Thanks in advance |
November 23, 2022, 09:24 |
Yann
Rep Power: 26 |
I'm not experienced with these solvers, but it seems sprayFoam capabilities have been included in reactingFoam. Have a look at the "Flow switches" section here: https://cfd.direct/openfoam/free-sof...s-constraints/ Cheers, Yann |
November 23, 2022, 09:40 |
Matteo
Rep Power: 4 |
Very clear, thank you very much
openfoam 8, openfoam 9, particlefoam, sprayfoam |
Sprayfoam Jet diverges | Klinge92 | OpenFOAM | 1 | August 10, 2018 09:21 |
Lagrangian Data extract from sprayFoam e.g. with swak4Foam | mokard | OpenFOAM Post-Processing | 2 | January 16, 2018 03:44 |
sprayFoam Evaporation Model | lx882211 | OpenFOAM Running, Solving & CFD | 8 | July 9, 2016 15:10 |
I want to add the Coulomb force to the parcel of sprayFoam. | kame | OpenFOAM Programming & Development | 0 | November 2, 2015 20:03 |
sprayFoam crashes | lukasfischer | OpenFOAM Running, Solving & CFD | 3 | July 14, 2013 11:08 |
