SimpleFoam convergence problems
Old   June 24, 2005, 05:09
Default As a newbie to OpenFoam I star
Klaus Schnitzlein
schnitzlein is on a distinguished road
As a newbie to OpenFoam I started to set up a simple example, i.e. laminar flow (no turbulence model) in a rectangular channel with inlet at one end and outflow at the other. At the wall the respective boundary condition is prescribed.
Despite the solvers for U seem to converge quite rapidly (I set the relative errors to 0 for U and p iterations) I encountered an ever increasing value for the continuity error. I tried to modify the grid, the superficial velocity, etc. but I failed to obtain a converged solution.
Any help is greatly appreciated.
schnitzlein is offline   Reply With Quote
Old   June 24, 2005, 06:01
Default Compare your case to e.g. simp
Mattijs Janssens
mattijs is on a distinguished road
Compare your case to e.g. simpleFoam/pitzDaily. Run that one without turbulence and see what happens.
Do you have empty patches? If so is your mesh only one cell thick and perfectly aligned?
mattijs is offline   Reply With Quote
Old   June 24, 2005, 06:33
Default I ran pitzDaily without turbul
Klaus Schnitzlein
I ran pitzDaily without turbulence, i.e.
turbulenceModel laminar
turbulence off
and obtained similar results, i.e. ever increasing
values for the time continuity errors.
Old   June 24, 2005, 07:00
Default So is your case steady 'in rea
Mattijs Janssens
So is your case steady 'in real life'? Is it turbulent? Are you trying to simulate a non-physical problem (e.g. simulate a turbulent flow without a model for the turbulence)
simpleFoam might converge if your flow is steady. But if it isn't you can run turbFoam and see if that reaches a steady state.
Old   June 24, 2005, 07:15
Default Not surpised that pitzDaily bl
Eugene de Villiers
eugene is on a distinguished road
Not surpised that pitzDaily blows up, it is a turbulent flow. If you do not have enough damping in the form of modelling and/or numerics you will get a build up of turbulent energy in your velocity field. Basically, the flow will just become more and more unstable untill it blows up. There are many good reasons why turbulence models have to be used, and this is one of them.
Try increasing your viscosity until your duct is in the laminar regime i.e. Re(b) < 1000~3000.
eugene is offline   Reply With Quote
Old   June 24, 2005, 07:20
Default And/Or the instabilities are c
Eugene de Villiers
And/Or the instabilities are causing inflow through your outlet boundary, which is probably why you are getting the continuity errors. Using a properly specified inletOutlet boundary should "fix" this.
Old   June 24, 2005, 09:51
Default Thank you for your comments an
Klaus Schnitzlein
Thank you for your comments and suggestions.
According to preliminary test runs the problem
may be may be solved at least partially by specifying an inletOutlet boundary.
SimpleFoam convergence problems brahim OpenFOAM Running, Solving & CFD 20 June 9, 2015 09:09
Problems with the RSM in simpleFoam sberg OpenFOAM Running, Solving & CFD 10 February 25, 2014 19:39
SimpleFoam Convergence problem skabilan OpenFOAM Running, Solving & CFD 6 May 31, 2013 03:21
SimpleFoam solution convergence pattern philippose OpenFOAM Running, Solving & CFD 0 June 26, 2008 14:18
SimpleFoam problems with converging maybe skewness hoochie OpenFOAM Running, Solving & CFD 4 May 14, 2007 07:23
