May 11, 2005, 15:21 |
Hi All,
Does OpenFoam have an
diablo80@web.de
Rep Power: 17 |
Hi All,
Does OpenFoam have an explicit scheme to calculate the Grad(U) at cell faces, like simply taking the difference between the two values at adjacent center points and dividing by the distance? Thanks Luiz |
May 11, 2005, 15:27 |
Try snGrad:
OpenFOAM-1.1/sr
Hrvoje Jasak
Rep Power: 33 |
Try snGrad:
OpenFOAM-1.1/src/OpenFOAM/lnInclude/snGradScheme.H Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
May 11, 2005, 15:40 |
Thanks Hrvoje,
But I wanted t
diablo80@web.de
Rep Power: 17 |
Thanks Hrvoje,
But I wanted the full gradient, i.e. the tensor, not the surface normal. Probably I will have to implement one based on snGrad, right? Thanks a lot, Luiz |
May 11, 2005, 15:43 |
The difference between the two
Hrvoje Jasak
Rep Power: 33 |
The difference between the two values around the face gives you just the surface normal gradient.
For the full gradient, interpolate the cell centre gradient and if you're really keen, rip out the surface normal component and replace it with the face snGrad. Hrv
Can't connect faces | Magic | FLUENT | 2 | December 5, 2008 07:18 |
[Technical] Mapping cell faces to other cell faces | doug | OpenFOAM Meshing & Mesh Conversion | 5 | March 30, 2007 02:43 |
UNREFERENCED FACES | Animesh | FLUENT | 2 | June 15, 2005 04:39 |
GradU in Post | sch | CFX | 5 | September 4, 2003 16:56 |
shadow faces! | Andrew Flintoff | FLUENT | 3 | July 2, 2002 16:11 |
