Wallfunctions onoff
Old   April 28, 2005, 04:44
Default Hi, A simple question. H
Rasmus Gjesing
gjesing is on a distinguished road
A simple question.
How is wall-functions for RANS disabled and enabled?
To me, it looks like in turbulenceProperties that wall-functions can be chosen on the same level as choosing the k-epsilon model. But I can also see in the implementation of the turbulence models that the source files for the wall-functions are included.
Thanks in advance,
Rasmus
gjesing is offline   Reply With Quote
Old   April 28, 2005, 04:47
Default All high-Re RANS turbulence mo
henry is on a distinguished road
All high-Re RANS turbulence models include wall-functions because it is inappropriate to use them without. Only the low-Re models operate without wall-functions as they include model-specific wall treatments.
henry is offline   Reply With Quote
Old   May 4, 2005, 03:14
Default Sorry, I forgot to mention abo
Masashi IMANO
imano is on a distinguished road
Sorry, I forgot to mention about my calculation setup's detail.
1. I'm running high-Re RANS.
2. I need to apply the rough wall function only to a ground and other walls
should be calculated with normal slip wall function. So I would like
to change wall functions whether a wall is a ground or not.
Since I'm beginner about both OpenFOAM and C++ language;;,
I would like to copy and modify the wall function sources directly,
but I still need to switch wall functions with using information of
the wall.
[Q] How can I switch wall functions according to wall's
information(name?) in RANS wall function sources?
Thanks for your advice,
Masashi IMANO
imano is offline   Reply With Quote
Old   February 10, 2010, 10:01
Default Production term
anonymous
muellea is on a distinguished road
Dear Henry and RANS-experts,
first of all, thank you for the improved near wall treatement (NWT) of kOmegaSST. I really appreciate it.
However, to have a reliable NWT, 2 questions may arise:
1) Production term:
  • From my point of view, the production term of k (called G) looks correct for small y+ and within the log-law region, but the if-condition may cause problems, if y+ is in the buffer layer.
  • Some paper propose a smooth blending of this term, which is perhaps less problematic than the implemented if-condition.
  • As far as I know, Menter never said (mentioned) a single word about this term. "Just one of this annoying secrets of CFX "
  • Fluent proposes that one can use the following formula everywhere, as long as tau_w is consistent with the velocity gradient based on the "automatic wall function". G=[(tau_w)^2]/(kappa*rho*(C_mu)^0.25*sqrt(k)*y)
  • What do you think about that? Is the implemented G unproblematic with respect to the buffer-layer?
2) Turbulent thermal diffusivity:
  • If we use wall functions for alphat, the following formula is used: alphat=mu_t/Pr_t
  • A lot of papers use the temperature profile proposed by Kader. Do you think such an adaptation leads to significant better results in cases with adiabatic walls?
Any comments are welcome. Thanks
Andi
Ps.: As english is not my mother tongue, some statements may sound a bit rude. If this is so, don't take it amiss. It was never my intention.
muellea is offline   Reply With Quote
Old   February 10, 2010, 10:17
Default Sorry
anonymous
Sorry, wrong thread
Old   February 10, 2010, 23:55
Jiang
panda60 is on a distinguished road
I think it is very difficult to understand how wall function works in OpenFOAM.
When you select high Renolds number kEpsolon model, it will be automatically be used ?
Or when you select nutWallFunction, it will be automatically used ?
If velocity wall function will be automatically used, then temperature wall function how to use ?
for example, buoyantBoussinesqSimpleFoam, It doesn't have a variable for temperature to use wall function. As far as I know, alphat wall function can only be used for compressible flow. Am I right?
panda60 is offline   Reply With Quote
Bug in twoPhaseEulerFoam wallfunctions alberto OpenFOAM Bugs 1 February 9, 2007 14:15
