GradU at the faces
Like Tree1Likes
  • 1 Post By hjasak
Old   May 11, 2005, 15:21
Default Hi All, Does OpenFoam have an
diablo80@web.de
sampaio is on a distinguished road
Hi All,
Does OpenFoam have an explicit scheme to calculate the Grad(U) at cell faces, like simply taking the difference between the two values at adjacent center points and dividing by the distance?
Thanks
Luiz
sampaio is offline   Reply With Quote
Old   May 11, 2005, 15:27
Default Try snGrad: OpenFOAM-1.1/sr
Hrvoje Jasak
Try snGrad:
OpenFOAM-1.1/src/OpenFOAM/lnInclude/snGradScheme.H
Enjoy,
Hrv
Hrvoje Jasak
Old   May 11, 2005, 15:40
Default Thanks Hrvoje, But I wanted t
diablo80@web.de
Thanks Hrvoje,
But I wanted the full gradient, i.e. the tensor, not the surface normal.
Probably I will have to implement one based on snGrad, right?
Thanks a lot,
Luiz
Old   May 11, 2005, 15:43
Default The difference between the two
Hrvoje Jasak
The difference between the two values around the face gives you just the surface normal gradient.
For the full gradient, interpolate the cell centre gradient and if you're really keen, rip out the surface normal component and replace it with the face snGrad.
Hrv
sharonyue likes this.
Hrvoje Jasak
Can't connect faces Magic FLUENT 2 December 5, 2008 07:18
[Technical] Mapping cell faces to other cell faces doug OpenFOAM Meshing & Mesh Conversion 5 March 30, 2007 02:43
UNREFERENCED FACES Animesh FLUENT 2 June 15, 2005 04:39
GradU in Post sch CFX 5 September 4, 2003 16:56
shadow faces! Andrew Flintoff FLUENT 3 July 2, 2002 16:11
