April 12, 2005, 05:39 |
at our institute we did
Fabian Braennstroem
Rep Power: 19 |
at our institute we did some modifications in fluent for the standard k-epsilon model via 'user defined functions'. The simplest ones were just to modify the source terms. Doing those modifications should be pretty easy in OpenFoam too; at least I expect that for an opensource code. Now, I took a look at the files in OpenFOAM-1.1/src/turbulenceModels/incompressible/kEpsilon there are two sections for the dissipation and kinetic energy eqn. Is this the only place I should care when adjusting the model or are there more to look at? Then a Allwmake for the source should do the job to integrate the new code!? Best Greetings! Fabian |
April 12, 2005, 08:09 |
You are right. All the code sp
Mattijs Janssens
Rep Power: 26 |
You are right. All the code specific to the incompressible k-epsilon is in that directory.
Better even would be to create a copy of those files and rename them (and the class inside them). Make sure you change the TypeName in the .H file as well. Compile them (change Make/files) and you'll have your own turbulence model. |
April 12, 2005, 09:52 |
Hi Mattijs,
thanks! That so
Fabian Braennstroem
Rep Power: 19 |
Hi Mattijs,
thanks! That sounds great! I think that helps to convince my Prof. using it :-) Greetings! Fabian |
KEpsilon model k_oldTime not working | harly | OpenFOAM Running, Solving & CFD | 2 | December 10, 2008 13:13 |
Modify kEpsilon model | harly | OpenFOAM | 5 | December 3, 2008 17:43 |
About kEpsilon turbulence model | osimonsimon | OpenFOAM Running, Solving & CFD | 10 | April 24, 2008 02:52 |
NACA0012 Study kepsilon Model | pda | OpenFOAM Running, Solving & CFD | 1 | March 11, 2008 03:12 |
mshaADD A NEW RELATION TO kepsilon MODEL | msha | OpenFOAM Running, Solving & CFD | 3 | January 6, 2008 07:06 |
