Try DB() -> db()
Try DB() -> db()
To clarify, I mean:
replace D
To clarify, I mean:
replace DB() with db() |
Also you might find it useful
Also you might find it useful to read the ReleaseNotes that are provided with 1.1
replacing DB with db is not wo
replacing DB with db is not working, fortunately I got the right corrections from Hrvoje.
Thanks again... I have another question, I have another application that is not working on 1.1 I get the following error message: GradU.C: In function `int main(int, char**)': GradU.C:104: error: 'struct Foam::volTensorField' has no member named 'xy' make: *** [Make/linuxOpt/GradU.o] Error 1 it refers to the line: volTensorField GradU ... GradU.xy() Can somebody help me? Daniele |
Try:
gradU.component(tensor
Try:
gradU.component(tensor::XY) Hrv |
Did you application work in 1.
Did you application work in 1.0.2? volTensorField has never had a member function xy() so it should fail to compile in all versions of FOAM.
the modification
gradU.comp
the modification
gradU.component(tensor::XY) is working, thanks again!! Yes, my application was working well in 1.0.2, I am sure. Daniele |
It doesn't make any sense to m
It doesn't make any sense to me that the .xy() function call for volTensorField would work in 1.1 but not in 1.0.2 given that the function isn't in eitehr version of the code. Do you still have a working installation of 1.0.2? Could you try compiling that piece of code and send me the details?
I apologize,
I tryed to reco
I apologize,
I tryed to recompile my application in 1.0.2 and it is not working.. Since I used that application to get results before, the only explanation for my mistache could be that I changed the source file in that way without recompiling it. I am very sorry. |
