Time step for icoFoam
Old   March 3, 2005, 17:19
Default Is it possible to let the ico
Ho Hsing (Hsing)
Is it possible to let the icoFoam calculate "deltaT" by itself to satisfy the CFL condition instead of setting to be a fix value?
Old   March 3, 2005, 17:24
Default Dynmically adjusting deltaT i
Henry Weller (Henry)
Dynmically adjusting deltaT is used in several OpenFOAM codes but not in icoFoam because that is simple example code which we wanted to keep as simple as possible. However, it is easy to add this functionality, have a look at say interFoam and transfer the relevant parts across to icoFoam.
Old   March 9, 2005, 18:24
Default Thanks, Henry, I added a coup
Ho Hsing
hsing is on a distinguished road
Thanks, Henry,
I added a couple of lines copied from the interFoam.C to icoFoam.C in order to make it dynamically adjust deltaT. The new solver runs fine for single node computing. However it gets into trouble when I set it to run in parallel mode.
Do you know what kind of problem it may be?
hsing is offline   Reply With Quote
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
SELECTING TIME STEP SIZE, NUMBER OF TIME STEP NITUL KALITA FLUENT 2 November 22, 2012 08:28
IcoFoam time fabrizio OpenFOAM Running, Solving & CFD 2 January 19, 2009 07:58
IcoFoam diverges with smaller step why rafal OpenFOAM Running, Solving & CFD 0 August 30, 2006 10:24
Relation of computational time step with real time Salman Main CFD Forum 2 August 3, 2005 14:13
